"Brick" means corrupting your Firmware, the system that makes your PSP run. Bricking can be caused by either "interrupted update of firmware" or attempt to install "PSP Hacks" also known as Jailbreaks or Custom Firmware (CFW).
Some PSP Models can be revived when bricked by using a system called "Recovery Menu" which becomes available when the PSP was running a CFW before it bricked. Another way of unbricking a PSP including those that runs Original Firmware is using Pandora Battery and a Magic Memory Stick.
However, there are PSP MOdels that cannot be unbricked. These are the PSP 2000 Slim that have the Motherboard TA088v3 and other higher end. The worst PSP Motherboard is the TA088v3 because once bricked, PSP becomes a lovely paperweight without game functions and possibility to be revived.
PSP Custom Firmware 6.35 PRO-B4 has been release by Virtousflame (a.k.a liquidzigong) and coldbird. The latest release includes a few bugs fixes for better stability and compatibility for all model PSP System (PSP 1000, 2000, 3000 and PSP GO - N-Series) .
This CFw has works on Sony firmware (OFw) 6.35 to lets users play backup UMD's - ISO games, so if you're already on OFw 6.35, you can either use this, If it doesn't, you will need to update your PSP firmware to 6.35.
Required :
PSP-300x or PSP-200x TA-088v3 or PSP GO has Sony Firmware '6.35' installed. other firmware is not supported. If you don't have PSP 6.35 installed, you need to update it.
Version check: On the PSP Menu (also known as XMB= Xross Media Bar), and goto 'Settings Menu' >> 'System Settings' >> 'System Information' and you should see firmware version of your PSP.
An Memory Stick at least 32mb for OFw update & CFw 6.35PRO-B4, ( Internal storage for PSP GO ).
Installation Instructions : Note: This software is free, and comes with no warranty, it has been tested and it has work, however I am not responsible for any bricked, so please try this at your own risk!. If you're afraid of risk of brick, don't try to downgrade. Read more...
1.)Here are some termins i will use: OFW-Original firmware,this is your system software CFW-Custom Firmware,Modified firmware HEN-Homebrew(home-made)enabler,this is much like a CFW without some features and its not permanent this means its gone after a hard reboot(taking out the battery or completly shutting down the system) XMB-CrossMediaBar your PSP menus PANDORA battery-a modified battery that allows you to put your PSP in service mode and do wathever you want with it its used for unbricking,downgrading and installing CFW. BRICK-Its when you mess with your system software and damage it,its called flashing,its called a BRICK since your PSP becomes useless as a brick. 2.)PSP 1000 (FAT/PHAT) This is wath it looks like:
ANY PSP 1000 is hackble Ways of hacking: 1.You can use a Pandora Battery that you have to buy *how to use a Pandora Battery:after you buy a Pandora and a MMS(Magic Memory Stick) insert them in your PSP and you shoud see a menu with CFW you have on your MMS. 2.)CFW or HENs depending on your firmware you can use CFW or HEN without pandora. PSP 2000 with non V3 MOTHERBOARDS:SAME as PSP 1000
PSP 2000v3/3000/Go:
3000
Go
1.)On the 2000 and 03g 3000 you can have LightCFW or HEN on 4g 3000 and GO you can have only HENs CFWs:5.03 GEN,6.35 PRO-B,5.50 GEN HENs:6.20 TN HEN
LINKS: http://www.psp-hacks.com/file/2052 6.35 PRO-B http://www.psp-hacks.com/file/2046 6.20 TN-C http://www.psp-hacks.com/2009/12/15/psp-custom-firmware-5-50-gen-d3-and-5-03-gen-c-for-hen-released/ 5.50 and 5.03 GEN
I really hope you didn't try to put custom firmware on it if its a slim with a TA088V3 motherboard or if its a 3000. If you did, its a brick. A permanent brick.
Since ChickHEN is out PSP-2000 owners with a TA88v2 or less or a TA90v1 motherboard now have the option to now install Custom Firmware without the need of a Pandora battery.We have put together a Easy installer that contains everything you’ll need. Hellcats Recovery flasher, ChickHEN, PSP firmware update 5.00. ********************************************************************************** Warning make sure you only try this on a PSP that will accept PSP Custom Firmware flashing (Custom IPL) otherwise you will brick your PSP!!! PSP-3000’s will not take CFW. Check your PSP will take CFWhere. Or run ChickHEN first, then when ChickHEN is loaded run PSPident from the Game XMB menu. (PSPIdent with install with this easy installer) Steps to install CFW on a PSP Slim without a Pandora battery. *********************************************************************************** 1. Check and triple check you have a hackable PSP that will accept custom firmware flashing without resulting in a BRICKED PSP. Make sure you have a PSP with a TA88v2 or below only + or TAv90v1. If your PSP has a TA88v3 or above or is a PSP-3000 DO NOT proceed!!! You will brick your PSP. Run the installer and point it to your Memory stick Pro Duo root. 2. If you don’t have don’t have PSP firmware 5.03. Get that here: PSP Firmware 5.03 Make a folder called UPDATE in your PSP/GAME folder and place the eboot in there on your memory stick pro duo. 3. Now lets run ChickHEN to have a homebrew enabled environment. In your PSP go to photo then click the ChickHEN photo and wait. If the PSP jams, please retry. If it flashes colours and reboots you have loaded ChicKHEN. Check your system info to be sure it say’s 5.03 ChickHEN R2. If you need help getting ChickHEN to run please visit this post. 4. Now with your PSP rebooted in ChickHEN go to your PSP XMB game menu and run Hellcats Recovery and install 5.00 M33!!! Your PSP will reboot, follow the instuctions to install PSP Custom Firmware 5.00 M33. After your done you can update to 5.00 M33-6 Easy ChickHEN CFW installer (Without Pandora) (27.9 MiB,)
In order to run isos which one downloads online one must first install custom firmware on your psp. The only way to do this is to downgrade your psp to 1.5 which can only be accomplished by using a pandoras battery. These are extemely easy to make and u can look on any website to find directions. They can also be bought for relatively cheap if u dont like the idea of cutting your own battery open. Please note that if u do decide to downgrade and install custom firmware ur psp runs the risk of bricking which will completely break it. Installing custom firmware voids the warrenty so if it does brick you can do nothing about it, do so at your own risk.
The only way to get downloaded PSP games to work is to have custom firmware. Custom Firmware also dont brick your PSP unless you interrupt your PSP while upgrading your PSP.
you have bricked your psp usually done by a crash in an update look into a pandora battery do not try to make one yourself and get you also need a magic memory stick look them uo on google but do not fall for scams if you shop online
