ViewSonic V36 Pocket PC Logo
Posted on Dec 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It says wait fifteen seconds and thats it - ViewSonic V36 Pocket PC
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Dec 03, 2009
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
286763
Points
2705
I believe you have an application that is conflicting with the system.
On the back of the device is a battery power switch, you will need to flip this and hard-reset the device. WARNING: You will loose all the information on the device.
At this point you can try updating, restoring your data, and then re-install your applications one at a time.
My laptop fail to start it only light up the power button and the fun .the monitor remains off .i left it working before
Hold the power button down until the computer powers OFF. Wait ten or fifteen seconds and push the power button. It should turn on normally with the monitor coming on also.
Our GE Triton TriClean III didn't drain, and now won't even give me an "on" signal when I lock it. Is it dead?
Check the circuit breaker before you make any hard-and-fast decisions. Find the appropriate circuit breaker, turn it off, wait fifteen seconds, then turn it back on. Now try it.
Aug 12, 2014 • Dishwashers
My samsung galaxy tab 2 the biger one is all screwed up on the screen its all rqinbow and like th eresolution is wack plez help
Hold down the power switch until it shuts completely off then wait ten to fifteen seconds and turn it back on. That should correct the screen issues.
1helpful
2answers
Kindle fire screen repair
Press and hold the power button for fifteen seconds or so. Does it turn off then? If so, press and hold the power button for a second or two. Does it start to reboot then? Does it work properly now?
Car stalle Security light on
Try your spare key.It could be that the primary key you have been using needs to be reprogrammed,which can be done by contacting a dealer.Turn the key to the "On" position in order to reset the pass lock system.Wait for fifteen minutes with the key in the "On" position.If the security light disappears, turn the key to the "Accessories" position and wait for a couple of seconds.Turn the key to the "Off" position and take it out from the lock cylinder. Wait a couple of seconds and turn the car on.--------------------------------------------------------------------------------------
Autel MaxiDAS DS708
1helpful
My car anti-theft seems to have kicked in and I can't get it to start. What do I do next?
hi, you can perform the reset with just your key and a battery charger to see if this will allow for restart. what you do is, hook up a battery charger to start with, low amperage setting like 15 amp, or maybe 2 amp, and leave it on the battery, you will be leaving the key on for up to an hour and the battery must not die during this time. turn the key on and try to start once for about 1-2 seconds, then let go and let key rest in run position for fifteen minutes at minimum. then turn off the key, wait ten seconds, and turn on again to run position only, leave on for another fifiteen minutes, then again, turn off for ten seconds, turn back on to run position for fifteen minutes. after this time, turn the key off, wait ten seconds, and try to start the car. if it starts, check to see if the check engine light is illuminated, or the security light is on, if one or the other is on, take to a shop and have codes checked and diagnosed, if no lights on, you should be able to drive on. if the vehicle does not start after three reset key cycles, try the process one more time. it may have been interupted somehow. if you try twice and still no start, you have to have diagnosed further, maybe in the key, maybe in the lock cylinder, maybe in the theft module.
I need to know how to do a hard reset on my d link router.
what you do is unpulg your ethernet cord, and then unplug your power cord, and wait ten to fifteen seconds, then press and hold down the power button while you plug the power cord back in, and that should hard reset your d link.
Help
Hold down power button for fifteen seconds or wait until battery completely dies.
1helpful
Frozen sansa
Hold down the power button for fifteen seconds. Wait ten seconds before turning the device on again to let the RAM clear out.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
