Intermittent problem (now permanent) of scanner software not seeing the scanner. First it was an intermittent Microtek software problem so I uninstalled and installed VueScan software. It worked for a short time, but then started having the same intermittent problem. Now it doesn't connect at all. Was connected via Firewire and tried via USB with same result (it's not the cable).
It's not a software/driver/source problem. It's a hardware problem. After checking around, the consensus is that my Microtek scanner is a paper weight (not worth fixing).
