This helped me with my scanmaker 3830 on windows 7 and windows 8 64bit too
You can download: ScanWizard 5 version 6.63
Here: ftp://microtek:[email protected]/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop.
1. Plug in your Scanner
2. Go to Control Panel (Windows 7,8 - 64 and 32 bit)
3. Go to Device Manager
4. Go to Imaging devices (or Other devices)
5. Find what windows have installed Right Click
6. Update Driver Software..
7. Click - Browse my computer for driver software
8. Click - Let me pick from a list of device drivers on my computer
9. Click - Have Disk
10. Browse to your desktop or position where you extracted 6.63, point
to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I
picked first
11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800
then USB 2.0 and both works., install the scan wizard,
restart the computer
Posted on Dec 17, 2012
Scanner microtec 3830 works with windows 8 pro and this is how
First install driver v6.63 as usb 2.0 as described above by errogen
then install scanwizard 5 v6.13 and thats it.
That dog is saved once more.Hope i helped
Posted on Mar 24, 2013
SOURCE: I would like to get
as this is a discontinued product the driver for windows 7 is not yet available any way you may visit "http://202.39.72.2/Singapore/Web/driver-page/discontinued.php"
and download driver and install this may also help in windows7
Posted on Aug 20, 2010
SOURCE: Can't get windows 7 64bit drivers for Scanmaker
ideas yes will they work probably not if you have a copy of server 2008 windows you can pull the driver from the disc it might work or craiglist the scanner and buy a new one SORRY no driver exists and i doubt one ever will it is a discontinued bottom of the line product
Posted on Dec 06, 2010
SOURCE: Microtk Scanmaker 3840 driver for windows 7
The scanner is not supported by Microtek for Win7. Since Windows 7 didn't find a generic driver (TWAIN) in its driver code, one option exists in Windows 7 Pro and Ultimate. Download and install the virtual XP mode (two programs are needed), then use the XP drivers and install the scanner to the "XP computer". You may need to store files on external media to transfer them between the "two" computers.
The XP drivers are here:
http://support.microtek.com/product_dtl_2.phtml?prod_id=32
I hope this helps.
Posted on Feb 27, 2010
SOURCE: my scanmaker 3600 doesn't work
There's no driver for Windows 7, But you still can install it so it can work by install the driver for Windows XP in "Compability Mode". here's the steps : 1. Place the applications installation file on the Desktop. 2. Right Click the applications installation file and select Properties/Compatibility Tab. Select "Windows XP" cheers
3. Click Apply/OK.
4. Right Click the file and select the Run As Administrator option to install.
Posted on Feb 08, 2011
3. Click Apply/OK.
cheers
