The speakers are intergrated in to the monitor. I can't hear anything even though it is all connected
First, find out if the speakers or audio is working properly. At your PC menu, left click Setting, Control
Panel, and Add hardware. Click the add hardware wizard and just follow the instruction until you will find all the installed hardware of your PC. Click at the Audio, and the sound driver of your PC to find if these are working properly. Assuming that this are working
properly, test the audio output of your PC by putting
in another set of speaker (borrowed or otherwise).
If you hear the sound, then it is a connection problem. The wire to the speaker could be broken, or
the speaker itself. Under this condition, it is your
option to open up your monitor and test the speakers.
Or to just buy a new set of speakers. Unless you
are familiar with handling an open monitor, you may
go ahead with opening the monitor Otherwise, it is
wiser to buy the speakers which is much cheaper
than a monitor that could accidentally get damage.
