20 Most Recent Insignia D300a PC Desktop Questions & Answers
Realty LTD, the following depends on your company's policies but if you are allowed, first thing is to check for driver updates in both Windows Update option and device manager. For Window Updates, Control Panel>System and Security>Windows Update. You may see links for important and optional updates. Check in both and look for specific hardware related drivers, not windows security and os updates. If there are any only update those. Next check Device manager. Control Panel>System and Security>Administrative Tools>Computer Management>Device Manager(on left panel). If there are any yellow yield signs and a carrot is open, right click it and select update driver. If none of this works please clarify further. Is the sound like a fan? Do you feel accompanying heat? Does it get loud only when using specific applications or is it all the time? Things like that.
Insignia D300a... • Answered on Oct 25, 2015
try Microcenter.com or frys.com http://www.frys.com/
Insignia D300a... • Answered on Oct 13, 2014
have you try another vga cable?
Insignia D300a... • Answered on Mar 16, 2014
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Remove it and put it back in place until the tabs pop out. Loose RAM can cause your computer not to start properly where you want to see a video signal. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots, lightly rub alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead.
Unplug all electronic cords connected to the computer.
At no time during the installation should any cords be connected to the computer.
Remove the screws holding the computer cover case, and remove the cover case.
Locate the computer power supply box, which looks like a large box out of which a bundle of wires run and connects to the power cord jack on the outside of the computer case.
Unplug the power cables from the internal devices connected to it.
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember write it down if you need to what devices will need reconnecting to the new power supply when you finish the installation.
Unscrew the power supply from the inside of the computer case and remove it.
Check the original power supply's red voltage switch for the correct setting.
It should read 120 or 240 if you live within the United States.
Confirm this setting as the correct voltage setting for your power outlets.
Make sure your new power supply gets set to the correct voltage setting before you install it.
If it cannot be set to the correct voltage, do not proceed with the installation or you may damage your computer.
Return the new power supply and buy one that is compatible with the voltage requirements.
Install the new power supply, reattach the screws that will hold it in the proper place inside the computer.
Reattach the power cables that come from the new power supply to the devices that were connected to the old power supply.
Make sure all of these connections are firmly in place before you turn the computer back on.
Reattach the computer power cables and all the cords connected to the computer during normal operation, but do not close the computer case yet.
Keep your hands clear of the inside of the computer case as you attach power cords and peripheral devices.
Turn the computer on and observe the performance of the computer without touching anything inside.
Do all the computer fans function normally?
Does the computer operate as well as or better than before?
If you feel that the computer behaves normally and you do not encounter any problems, turn the computer off, remove all the power cords and peripheral cables once more, and close the computer case.
Then reattach the power cords and peripheral cables and begin using the computer.
Check for errors if you encountered any problems starting the computer or if it would not start at all, unplug all the power cords and computer cables connected to the computer and look inside.
Make sure that you connected all the correct power cables inside the computer securely and did not miss any.
If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation. Most power supply units will fit Like everything else in our high-tech world, power supplies come in myriad sizes and shapes you should check all the electrical connections before you make a decision and make sure they are the same as the ones that you will need to run your computer also Check the measurements inside the frame to make absolutely sure it will fit,
http://www.youtube.com/watch?v=mKw0bij8CDsHope this helps
Insignia D300a... • Answered on Nov 14, 2012
When you turn it on is there a BIOS message on screen to press a certain key like F5 or F10 for instance.
Insignia D300a... • Answered on Oct 10, 2012
Solo tienes que comprobar eBay de vez en cuando. Alguien que eventualmente tendra una venta de primer plano.
Insignia D300a... • Answered on Jun 11, 2012
Rosa,http://www.insigniaproducts.com/products/computer-speakers-accessories/D300a.html?supportTab=openUnder the green subheading -Drivers, Firmware, and Software;Left-click on - Audio Driver - Realtek Integrated Audio driverRemember; download AND install.Need guidance? Post back in a Comment.Regards,joecoolvette
Insignia D300a... • Answered on May 11, 2012
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Insignia D300a... • Answered on Sep 01, 2011
You need to go to the website of the cards company and download the drivers for the card. If it is a PCI card then make sure that it is seated properly on your motherboard. If you switched the card to a computer with a newer operating system then it might not be compatible.
Insignia D300a... • Answered on Aug 25, 2011
http://www.crucial.com/ will scan your computer and tell you what kind you need. the amount you need is dependent on what you are going to use the computer for if you are going use it if you are going to be doing heavy networking, video editing or anything like that i would say 4 gb of ram but 2 gb runs a pretty good computer.
Insignia D300a... • Answered on Jul 01, 2011
Hi there!
The Insignia D300a uses Realtek Integrated Audio. You can download the compatible driver from this link.
Regards!
Insignia D300a... • Answered on Jun 10, 2011
You need to change the boot order to make the machine read the cd drive first.When starting the computer you need to press F2.This will get you into the start up bios menu.Find the boot order and make it use the cd drive as the first device.Now restart your machine withe the cd in the drive.
Insignia D300a... • Answered on May 30, 2011
I don't have one of these, but from looking at the picture then I am guessing there is probably a couple on the back. They should be up the right hand side, with all the other ports. There will be some on the back somewhere.
Hope this helps.
Insignia D300a... • Answered on May 25, 2011
This is a discontinued model. There driver can be found at the Insignia website , under support&servcie then Product Specific, then type in the model number of your machine.
I have included the link. Click on Audio Driver and it will download on to your machine
http://insigniaproducts.com/products/computers/D300a.html
Hope this helps
Insignia D300a... • Answered on Mar 07, 2011
i can be a virus deleting some system files
Insignia D300a... • Answered on Mar 05, 2011
OK, is it new? Or have you already had it on the computer?
Insignia D300a... • Answered on Feb 24, 2011
May I know since when you are facing this issue? The symptomps you have described tells that it might be an issue with the operating system of the pc. looks like you are using windows xp in your pc. You can try running a system restore. Start>All Programs>Accesories>System tools>System Restore. Then you will get the window of system restore and you will have click on the option that says Restore My Computer to an earlier date/earlier point in time. Once u click on that it will show u the calender. If u are sure about the point in time from which u r facing this issue look for the date. But you will be able to restore ur pc only to those dates that are marked in bold. Click on that date and keep hitting next until it starts the restoration. If it does not help then try this. Click on start>Control panel>Add or remove programs. once the add or remove programs window comes up on the left hand column u will get an option called Add/Remove Windows Components. On the list that comes up u will get the options for Internet Explorer and Outlook Express. Uncheck them and restart the pc. And follow the same process to put check marks on those two options. IF this does not help most likely u will have reformat the hard drive and reinstall windows. If u dont want to run the format then u can use another browser like mozilla firefox and use another email client like Windows live mail and u can download them free from web. http://www.mozilla.com/en-US/firefox/ is the link to download mozilla firefox and http://explore.live.com/windows-live-mail?os=other is the link to download the latest version of live mail.
Insignia D300a... • Answered on Feb 17, 2011
You can download the video driver from
Please rate this solution. Thanks.
Insignia D300a... • Answered on Dec 11, 2010
Insignia D300a PC Desktop Logo
Popular Tags
89 questions posted
Top Insignia Computers & Internet Experts
Michael Thomas
Michael Thomas
Kevin Nelson
Jax Planet
Jax Planet
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Computers & Internet
Most Popular Question
fix computer
  • Computers & Internet
