20 Most Recent
Kinyo PS-107 Computer Speakers Questions & Answers
Green power light not on
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
I cannot hear ANYTHING. The speakers are plugged
game controllers you might see a yellow question mark? Right click to reinstall
drivers or uninstall
settings there
also
icon in taskbar
problem
have you tried this control panel sounds and
connection is good
make sure you have an earth
******** before touching any parts inside your computer
hope this helps
Sound comes out of all
you might have to select stereo speakers in the drop down list
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
dont forget to vote
I cant get no sound its hook up right and i need
Here is a guide to the sounds on a computer
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
My computer had viruses so i got it fixed and now
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
hope this helps
My speakers are working at
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
What can i do if
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Speakers make no sound and not recognized
shut down the computer then unplug the speaker.then wait a little and restart it. as soon as it is ready,plug in the speaker. It should recognize and search for drivers. and the it should work fine. .
My computer crashed and now my speakers wont work
Hi:
You need to go to your computer manufacturer's website and download the drivers for your soundcard.
An example would be if you have a Dell computer, go to
www.dell.com,
click on their support/drivers link, type in the model of your computer, and download the proper file.
No audio
Hello
Have you remembered to install the sound drivers ?
If you have just reinstalled windows you have to install all the drivers for the needed devices as well in order for everything to work propperly. Hope this can solve your problem.
Best regards
Andrea
No sound when plugged into computer. can hear
check have you connected your speakers to the correct socket in your computer. try restarting your computer. if it still does not work then ask from the store where you purchased these speakers.
Help i just plugged in my kinyo speakers after not
I'm not sure what you mean by "jingle"..
The speakers are probably picking-up interference from a neighbour, radio-station, or -if occassional- a portable or cellular phone.
You can try moving the wires, or putting a snap-on filter on the wiring.. may help some.
Kinyo speakers will not work on my computer
First thing I would try is to figure out if this is a speaker problem or a system driver problem or hardware issue.
First, try using headphones from an ipod and plug them into your computer and listen. Check for the input and not to mistake the miocrophone input. They should be clearly marked. If it works then its your speakers.
If it does not work, you should try reloading your drivers. You can download the drivers from the company website or you may have the drivers on the system restore CD that came with the computer.
Another thing to try is to reinstall the hardware. Sometimes, their is a confict when you install devices like webcams. You can verify that you do not have a problem by contacting the webcam company. Try contacting the manufacturer of the computer if it is within the last few years.
Worst case, bring it in for a diagnostic to a local PC repair. Should be an inexpensive fix, less than 50.00
Hope I could help point you in the right direction
Mike
