If it isn't the heater coil, then the only things left are the heater fan fuse or the heater fan motor itself. Check your fuses. If you don't have a fuse diagram, start with highest amp fuses first. The heater motor uses a lot of juice and will probably be on at least a 10 amp fuse. If all the fuses are good then you probably need a new heater fan motor. They usually mount to the fire wall from the engine compartment and are pretty easy to change. Not at all like the heater coil.
SOURCE: heating core
they are normally inside the dash behind glove box. some can be very hard to get at since you have to take off entire dash board.
SOURCE: no heat.....although the thermostat is
Look for 2 hoses approx. 1"-1 1/2" in diameter going in to firewall behind the engine slightly to right of center. When your engine is warmed up & heater is on, feel them carefully, and see if both are hot , or only one is. You say for sure it needs to be replaced, why, is it leaking?
SOURCE: heating problems cold to worm heat
is coolant level ok? feel hoses if they are hot( small hoses going to interior) also possible interior radiator stocked. good luck
SOURCE: heater core problems no heat changed thermostat
try flushing cooling system could be a blocked heater core.if flushing doesnt work remove and replace heatercore.
