My mpc t1200 wont charge and also when it was charging before the AC/DC jack would always get really hot as well as the charger head
U have a battery with shortcircuit,
1st u need to test the charger without battery inside, for temp. and computer functions
2nd u need a battery spare, and test the same
if continues, send for repair shop for test and checkout
Sounds like your charger is not working, also it could just be your battery is no good. To check if it is the charger,remove the battery and see if the computer works with just the charger, if it is, it is your battery.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Problem symptoms:
