Either that or use the digital anti-shake function.
The problem with most digital cameras is that there is a slight delay between when you press the shutter and when the picture is actually taken. The only real solution is to continue hold the camera steady for a second or two after you think you've taken the picture. You can check the camera is ok by placing it on a firm, steady surface and using the self timer to take a picture. This picture should turn out ok. The reason that video looks ok is that as it's a moving picture slight movements by you are constantly disguised.
