Anonymous Posted on Nov 23, 2009
My ASK 16 GB mp4 player with camera won't play the video I transfer into it cause I accidentally deleted the software files in it after connecting to the computer. Also, I can't restore the software because I emptied the recycle bin.Anyone help me?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
160
Points
I format my mp4 through my computer & when the mp4 suddenly freeze, I just have to connect it to another USB cable to my computer & it'll start working again. Basically, you need 2 'USB cable' to interchange if your ASK mp4 start freezing.
Memory is fullmp4 player says plug into computer to delete songs how do I delete
You should have got a USB Cable to connect your mp4 player ti the computer.
The first time, your computer will take some time to install the new software so as to facilitate the transfer of files.
You can then go to My Computer and go to the respective mp4 player drive and there you can see the list of songs/videos that are available in your mp4 player.
Delete the ones whichever you want.
You can alternatively delete the files from the mp4 itself. Menu button would show the options.
tip
How to convert TS to MP4 on windows?
What’s the problem?
Q1: I record a couple of videos with my JVC camcorder, and I found these videos are in the MPEG-2 TS formats. Is there any idea about how to put these .ts videos on my iPod?
Q2: I downloaded a couple of HDTV olympic videos and I can't seem to play them.
It a .ts video file (transport stream) file, and I looked for a codec, but came out with nothing.
As we know that .ts files are not widely accepted by a lot of multimedia players or portable media players, so you will find a lot of troubles when you want to play your downloaded HD .ts video clip on your PC, or put a camcorder .ts video to iPod, iPhone, or other portable media players.
Solution to play .ts files on PC or iPod, iPhone and other portable players
How to solve these problems? The easiest solution is to convert ts to mp4 with TS to MP4 Converter. One of these options is Wondershare TS to MP4 Converter which can play .ts video, convert .ts video to MP4 which is widely supported by most players, and edit .ts video.
A simple guide to convert ts to mp4 with TS to MP4 Converter
Please free download Wondershare TS to MP4 Converter, install and run it. And then follow the steps below:
Step 1: Add .TS files
You can click "Add Video" or just drag & drop your .ts videos to the file list directly.
Step 2: Select MP4 as output format
Select MP4 as output format from the categorized output formats list in "Profile" drop-down list and specify the output directory to save your converted files in "Output" drop-down list.
Step 3: Start to convert TS to MP4
After everything is done, hit “Start” button to convert TS to MP4. And all the tasks will be done at fast speed and high quality. The conversion speed often depends on the original video size and your PC configuration.
Step 4: Transfer converted MP4 files to iPod/iPhone or other portable players
Now you can connect your iPod/iPhone, or other portable media player you own with PC, and transfer these MP4 files to it. You know most portable media player accepts MP4 format, such as iPod, iPhone, Walkman, PSP, Zune, Creative Zen, etc. Now, it’s time to enjoy your both downloaded or camcorder record .ts video on your portable media player.
Tags:
ts to mp4
convert ts to mp4
ts to mp4 converter
on Mar 22, 2010 • Cameras
1helpful
4answers
How to play mp4 video
Make sure that your handset supports mp4 videos.
You can play 3gp videos in your handset.
If your handset supports mp4 videos, then set your mp4 video's frame rate, bit rate and resolution.
Aug 07, 2012 • Cell Phones
How do i transfer video from laptop to mp4
Hi there.
To transfer the video from your laptop to your mp4, make sure that the video is a file that can be read by your mp4 player. In that case, it should be already an mp4 format.
Check if you need any software to be installed in your laptop for it to recognize the player when connected. Usually, a software installer is included in the package. Just download it.
Once installed, connect your player using the supplied cable to the laptop and start the transfer.
Hope this helps.
Let me know if you need any questions.
Thank you!
1helpful
Hi, I am using Philips Go Gear 4 GB MP3 palyer. It has 3 GB free space but when I start the player,below message comes . Please tell me how to solve the issue "Memory Full Connect to PC &...
Possible that some of the files in the GoGear are not to the requriement of the player. So download the media converter and download the files to be transferred to the player. In the first place connect the player to the PC and move OFF all the files , delete the memory to be free and then reload using the converter .
Use the link below:
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA3104-SA3105-SA3114-SA3115-SA3124-SA3125-MP4-Player-Media-Converter-Software-1-0/
5helpful
The videos when transferred from camera to the computer become inaudible. Please suggest how do i make them audible even after i transfer them to the computer.
1. It looks like a codec / media codec problem.
2. Install a multimedia player which can play the camera videos (.mp4, .mpeg, .dat files) like VLC Player, Real Player, KMP Player, etc.
3. You can also play these videos on the media player which came with the software bundle of your Kodak camera.
tell me if it helps...tc! :)
3answers
Can't play video I filmed on my computer
Try installing MCP Star player, it's free and it plays just about any video. Get it here http://www.mpcstar.com/
2helpful
6answers
Transfer videos to my sony nwz-s616f
Firstly; is it in the right format? You say MP4, but the video needs to be specifically MP4 - 320x240 screen resolution. It won't play if the resolution is incorrect.
So get that fixed up first if that's what's wrong (http://www.dvdvideosoft.com/ has a great program to convert videos to MP4). If not, sometimes my computer doesn't allow me to put files on it one way, but it will another, so try copy/paste instead of drop and drag. Hope that helps.
2answers
Cannot view video taking on my pc
You need to install the latest version of quicktime player to play .mov files, you can download a free version at www.apple.com
15helpful
4answers
Disk Error with my mp4 player
My Mp4 is saying disk error and bringing you want to format this disk Yes or No Question
 Grubhead
Grubhead
SmartAviator
SmartAviator
