Minolta Dimage Scan Elite 5400 Film Scanner Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I download a driver that will work in Vista for my Minolta Dimage Scan Elite 5400?
Anonymous
Level 3:
  • Master 466 Answers
  • Posted on Nov 07, 2009
Anonymous
Master
Level 3:
Answers
466
Questions
0
Helped
183055
Points
1494
Unfortunately support for your model has been discontinued. The most recent driver is here
http://ca.konicaminolta.com/support/americas/scanners/dimage-scanners/dimage-scanelite_5400/software_drivers/drivers/ver115_win.html
but only supports officially up to Windows XP.
If the driver does not work in XP SP3 and Vista, this may be due to full system access being required by the driver and/or its ancillary userspace software.
You can either try running it as Administrator, configure for XP or 2000 compatibility, or if nothing else works, you may be forced to install VMware or Microsoft VirtualPC and virtualize an ad hoc installation of Windows XP SP2 with updates inhibited, in order to be able to run the scanner. In enterprise environments whole PCs are often set aside to run outdated operative systems in a controlled environment; you may do the same thing with only one PC and VMware.
I am looking for a driver for the minolta discan 5400 on vista. Can you help me?
Well, I have not so good news. The DiMAGE 5400 II is a discontinued product at Konica Minolta. There was never a Vista driver for it, and there is no plan to develop one as the product is no longer being sold.
Hope that's helpful.
Will this scanner work on Vista or must I use in on a computer that has XP? How do I get it to work with Vista? Would it be easier if I got Windows 7?
You have to replace the original Konica Minolta driver with the custom one I have created below. Here are the detailed steps.
1) Install the Konica Minolta XP software in Vista/Win7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USBVid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USBVid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USBVid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USBVid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USBVid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USBVid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USBVid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USBVid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSIScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSIScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSIScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSIScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSIScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c: ewminoltasonyscanners.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta XXXX (depending on model) and click on driver tab. Select Update Driver.
10. Select Browse my computer for driver software.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c: ewminoltasonyscanners.inf and click OK
14. Click Next. Windows should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
17. If you are trying to use a Minolta 5400 with firewire in Windows 7, you have to change your 1394 driver to the legacy windows 1394 driver in order for the scanner to detect. Google for instructions as it's too detailed to add in here.
18. The above driver should relink virtually all known Minolta scanners (USB/SCSI/Firewire) to the Windows TWAIN driver so it will work with the legacy Minolta software.
5helpful
Does Kainanderson's solution work with Win7 64bit
Of course it does. I'm using both a Minolta Dimage IV and Minolta Dimage Elite 5400 Mk 1 (firewire and usb). Here's my latest driver:
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
3helpful
2answers
Connection problem (error4 ) Minolta Dimage 5400
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c:\newminolta\sonyscanners.inf)
13. Browse to c:\newminolta\sonyscanners.inf and click OK
79helpful
10answers
Minolta Dimage Scan Elite 5400 - Vista driver?
1) Install all of the usual Minolta software in Vista if you haven't already.
2) Create a new folder somewhere
3) Create a new txt file in that folder and name it minolta.inf and paste this into it:
; minolta.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Class=Image
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
[Models]
; USB scanners
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. Once installed, all the normal Minolta programs now work just fine. Enjoy!
I tested this on Vista 32 Ultimate with a Dimage IV but it should work on all the models listed in the .inf file.
2helpful
4answers
Driver
Second the Vuescan reco. That's what I use. OTOH, a dual boot machine with an XP partition can also solve the problem. A real PITA but feasible (I have one).
60helpful
6answers
Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
3) Create a new txt file named minolta.inf and paste this into it:
; scanners.inf -- Test Vista Minolta Film Drivers
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. All the normal Minolta programs now work just fine. Enjoy!
4helpful
2answers
Konica Minolta Dimage Dual IV
1) Install the Konica Minolta XP software in Vista/Windows 7.
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: ewminolta ewminolta.inf)
9. Right click on Minolta Scan Dual IV and click on driver tab. Select Update Driver.
13. Browse to c: ewminolta ewminolta.inf and click OK
14. Click Next. Vista should now say it updated driver.
2answers
MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
