Question about Minolta bizhub 180 Black and White Copier
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Posted on Oct 28, 2011
thank you very much, you've just solved my biggest problem!
not working
plz any other option
Konica minolta 164 (problem maintenance. Call)
Konica minolta 164 (problem maintenance. Call m2) please any other bcose there r no zero key option so please
THANK YOU
Posted on Mar 18, 2015
Not working this method on Konica minolta bizhub 195 to remove code M2..... so plz any one to give other way to solve the problem??????
Posted on May 07, 2017
