20 Most Recent Minolta bizhub 180 Black and White Copier Questions & Answers
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
10/13/2018 9:29:06 AM • Minolta bizhub... • Answered on Oct 13, 2018
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/28/2018 6:18:17 AM • Minolta bizhub... • Answered on Jun 28, 2018
3answers
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
3/17/2018 8:21:14 AM • Minolta bizhub... • Answered on Mar 17, 2018
What would be the genuine problem when konica minolta bizhub 215 shows maintainence call(m2)
Procedure 1. Press the COUNTER. 2. Press the following keys in this order: STOP 0 0 STOP 0 1 3. Enter the code number corresponding to the function to be used from the KEYPAD. 4. Press the START. <Exiting the Mode> • Press the AUTO RESET until the initial screen reappears.
1/19/2016 7:23:56 PM • Minolta bizhub... • Answered on Jan 19, 2016
MAINTANANCE M2 MINOLTA BIZHUB 163
Need to have the drum and developer and cleaning blade replaced, then have that M2 counter reset. Resetting the counter with out replacing the drum developer and cleaning blade will cause codes and image problems. Machine uses the counters to determine voltages for certain assy. If you clear the counter and not replace the parts the machine adjust voltages for the drum and developer assuming it new when in reality it is old. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/7/2015 8:15:39 PM • Minolta bizhub... • Answered on Feb 07, 2015
Minolta bizhub 195 Black and White Copier
Yes sir/mam what about it? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2015 10:31:52 PM • Minolta bizhub... • Answered on Jan 24, 2015
M1 m2 m4 screen messaege
Utility button then stop 00 stop 01. Then use arrows to clear data screen then clear counters. Has the drum and developer been replace do that before clearing the counters Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/19/2015 4:59:57 AM • Minolta bizhub... • Answered on Jan 19, 2015
Konica minolta bizhub 164 reset code m2
Utility button then stop 00 stop 01. use arrows to get to clear data. then to maintenance counter clear/yes Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/19/2015 4:50:21 AM • Minolta bizhub... • Answered on Jan 19, 2015
164 error code& solution
Sir could you please recheck the code looking at service manual no 164 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2014 10:34:46 PM • Minolta bizhub... • Answered on Dec 30, 2014
220 error code& solution
Sir/Mam what is the error code? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2014 10:32:39 PM • Minolta bizhub... • Answered on Dec 30, 2014
Maintenancecall 2
First it indicates that the drum needs to be replace along with developer. has that been done? Then who did it for got to clear the counter. Go to service mode Utility then stop 00 stop 01 . Then to # 9 Clear counter then to supplies life counter clear yes exit out Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2014 8:37:53 PM • Minolta bizhub... • Answered on Dec 30, 2014
C220 error code& solution
C0210 Abnormal image transfer voltage - The image transfer voltage remains more than 100 V continuously for a given period of time while the PC Drum remains stationary.
7/23/2014 4:23:20 PM • Minolta bizhub... • Answered on Jul 23, 2014
Bizhub 164 m2
Press the Utility button, then Stop 0 0 Stop 0 1 then scroll to Clear Data, and then Supplies Data and clear. You must be aware that clearing this counter clears the drum, developer and other counters. Which are very important for copy quality, and not replacing them may cause more harm than good.
7/23/2014 10:51:34 AM • Minolta bizhub... • Answered on Jul 23, 2014
Problem with Minolta bizhub 164 Black and White Copier- Maintenance M2 call service
press the Utility button, then Stop 0 0 Stop 0 1 then scroll to Clear Data, and then Supplies Data and clear. You must be aware that clearing this counter clears the drum, developer and other counters. Which are very important for copy quality, and not replacing them may cause more harm than good.
7/17/2014 5:21:06 PM • Minolta bizhub... • Answered on Jul 17, 2014
Kode m2 bizhub 184
7/17/2014 5:10:47 PM • Minolta bizhub... • Answered on Jul 17, 2014
M2 call service for 211
7/17/2014 5:07:46 PM • Minolta bizhub... • Answered on Jul 17, 2014
Konica minolta 164 maintanance call m2 error solutions
7/17/2014 5:05:55 PM • Minolta bizhub... • Answered on Jul 17, 2014
Bizhub 164 maintanance call m2 solutions iam neede
7/17/2014 4:52:56 PM • Minolta bizhub... • Answered on Jul 17, 2014
Konica Minolta bizhub 164 m2
7/17/2014 4:51:24 PM • Minolta bizhub... • Answered on Jul 17, 2014
Bizub 164 maintanence m2 code remove
7/17/2014 4:50:14 PM • Minolta bizhub... • Answered on Jul 17, 2014
Minolta bizhub 180 Black and White Copier Logo
26 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
maintenance m2 call service
  • Office Equipment & Supplies
