Brother LS-2125 Mechanical Sewing Machine Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The machine stops working and the handle will not turn
hmlee390
Level 3:
  • Master 736 Answers
  • Posted on Oct 20, 2009
hmlee390
Master
Level 3:
Answers
736
Questions
Helped
279933
Points
2447
Make sure you have properly lubed the machine ... your trouble is likely lint buildup or a scrap of cloth blocking the rotation of the mechanism under the machine ... you will have to take off the sole plate and remove anything that shouldnt belong there .. if that is not enough you may have to remove the bottom and check ... make sure the needle is going thru the sole plate hole and clearing the foot ... if its not then check for a bent needle or one that is in backwards (with respect to the flat side) .. you can check the motor to make sure its working ok by putting the machine in the bobin winding mode .. that disconnects the motor from the internal mechinism ... only the handle should turn in that mode ..
Im looking for a new handle for tipmatic 1027 - broke it in recent home move. machine still works well. The number on the handle is 035067
The handle is integral to the machine, so it sort of becomes a spare. As these people, as they may be able to order direct.
https://www.sewingpartsonline.com/pfaff-1027-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=1
or contact Pfaff direct
Sewing Machines - Pfaff
https://www.pfaff.com > en-CA > Machines > Sewing
Our most advanced machine combines our legacy of maximum precision with every best-in-class feature you demand. The result is a feat of technological excellence ...
or possibly have one fabricated, or repair the old one?
My up and down needle handle stopped turning all of a sudden. Why?
Without the make & model, we are really limited in providing an answer.
If it is an older mechanical machine, it may be seized due to lack of frequent cleaning and oiling.
Wheel on right side that controls the needle up and down is very tight...
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
The handle on my sewing machine stop turning up or down
could you please explain your problem a little more?
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Sewing machine needle breaks when I get to the edges where the fabric is thick and overlaps. The needles don't break anywhere else. Do I just need a bigger needle?
I will stop at the overlap and slowly go through the fabric by turning the wheel manually and carefully handling the fabric with both hands, for example, when hemming bottoms of pants where the seams are
1helpful
Pfaff Creative 1371
Did the machine get dropped, or otherwise roughly handled? Or have a rough, bumpy ride back home, etc? That could explain why it's not working correctly.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
