Kodak EasyShare V1003 Digital Camera Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens cap does not stay on; dropped and spring action is not working. Can you help? Thx
Pania Lee
Level 3:
Genius:
  • Kodak Master 1,099 Answers
  • Posted on Oct 16, 2009
Pania Lee
Kodak Master
Level 3:
Genius:
Answers
1099
Questions
Helped
219211
Points
1986
OoW. repair of 88,07 punds. Alternatively Trade up option. Where you trade your old camera for a new camera for a favorable price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
2helpful
3answers
I have a Casio cdp 100 keyboard and two of the keys are stuck in the down position. Almost like the spring has gone in these 2 keys. Can this be fixed and if so, how?
is it under warranty ?
if not
you may have to contact your point of sale to find their local repairer
if you cant un stick them yourself that keyboard will have to be taken apart
are the two keys ... white keys or black ...nearby or way apart
do the two keys drop loose..and lift up
or stay down
example will vacuum cleaner suction help lift the stuck keys or not
sales blurp says this
A spring-less hammer system
Scaled Hammer Action Keyboard
https://www.jbhifi.com.au/musical-instruments/casio/casio-cdp-120-digital-piano/91120
Jul 31, 2016 • Casio Music
Employee dropped it and the front cover that goes over the actual lens came off. there are two odd shaped pieces with springs.
Those are most likely the retainers that kept the lens cap secure in in place, if not broken, you should be able to put it back together.
Mar 25, 2015 • Cameras
The screen stays black. Yes, I have batteries, I do get instructions and images for video or camera, but I can no longer get a visual of anything the camera is aiming at. It's like there is a lens cap on...
Look at the front at the lens. Turn the camera to picture mode. Point the camera at a light above you. Take a few pictures and watch the lens.
You should be able to tell if is functioning correctly or if its broken. It sounds like it has been dropped.
Your Friend,
Sleek Mouse
Mar 15, 2011 • Cameras
I have a smasung L830 Digital camera, when I turn it on, the camera screen comes on breifly, it beeps three times, the lens stays in the shut position, and the blue light stays on. I cannot figure out why,...
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you!!
3helpful
2answers
Lens won't close.
I just found the culprit causing my camera to do the same. Under the battery door there is a post that hits a switch. That switch needs to be activated when the door is closed in order for it to work. Safety feature to allow someone not to put in a SD card while camera is on.
Lens cap will not stay open
try opening your camera in front unscrew the bolts and pull the front cover.you will see a metal cover not properly align.
2helpful
Lens cap stuck
I was messing around with this today, ended up where it seemed in was working.
Power up, let lens out, then take out batteries. Pry off silver band patiently using fingernails. Then pry off overlying black plastic piece. There are four units underneath, pay attention to how these are put on, mine popped off, but it wasn't too hard to figure out how to put back together. There are pins and holes and kind of fits like a jigsaw. Once off clean with alcohol where you can.
Put batteries back in and open and close a few times. This will help understand movement where pins of lens cover pieces go. When putting these back on make sure camera is in off position.
The lens cover pieces need to be put on so that the pin portion has some resistance. Move one so that it drops in then push up to get other in place. Let them come together and hold these in place.
The two smaller pieces will close the cover. Put the hole of the closer piece over the pin. Then move slightly so you can retract spring with a small instrument and subsequently engages pin on closer. Place top black piece back on, then silver.
This worked for me, hope it does you also! Good luck.
Lens cap
wrong !!!!!! the lens cap is proprietary to the camera I think I might have one if your interested?
Lens will not close....
hi
based on what you said, we can say that your cameras lens spring got mis-aligned thats why you have to maually pull it out.
you can bring that to any service center and hopefully they wont charge you much because they just have to re-align the spring...
hope this helps.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
