Zug adora 12s. d panel flashing lights, wont wash, standing water
I have a zug adora 12s. after a cycle, the dishes were cleaned, but water was left standing at the bottom of dishwasher. (clean water) now the panel lights keep flashing, and i think it wont start a new wash. what is the problem?
Perhaps the solution to your problem can be found in the User Guide-
Your model number appears with two suffixes; WW and BB thatmay only be color codes but user guides (which appear to be identical) areavailable for download from GE’s site:
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle. 2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open. 3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure. 4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms. 5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes. 6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent. 7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes. 8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
If the clean light blinks 7 times thats you heating circuit. Test the heater with an ohm meeting to see if it has open. If so order the heater kit and it comes with the control board.
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
