If the display on your Tony Little Gazelle Power Plus Glider Exercise machine lights up but doesn't show any counting, distance, or time information, there could be a few potential causes for this issue. Here are some troubleshooting steps you can take:
- Check Battery or Power Source: Ensure that the machine has a sufficient power source. If your Gazelle Power Plus Glider uses batteries, make sure they are fresh and properly inserted. If the machine is powered by an AC adapter, ensure it is securely connected to a working power outlet.
- Check Display Connections: Verify that the display module is properly connected to the machine. Inspect the cables or connectors for any signs of damage or loose connections. If necessary, unplug and reconnect the display module to ensure a secure connection.
- Reset the Machine: Try resetting the machine to its default settings. Depending on the model, this can be done by turning off the machine, unplugging it from the power source, waiting for a few minutes, and then plugging it back in. Refer to the user manual for specific instructions on resetting your Gazelle Power Plus Glider.
- Clean the Contacts: Over time, dirt, dust, or corrosion can accumulate on the electrical contacts. Use a soft cloth or cotton swab dipped in rubbing alcohol to clean the contacts on the display module and the corresponding contacts on the machine. Ensure that they are dry before reconnecting.
- Contact Customer Support: If the above steps do not resolve the issue, it may be best to contact the customer support of Tony Little or the manufacturer of the Gazelle Power Plus Glider. They will have specific troubleshooting advice and can guide you through any additional steps or recommend further solutions.
When contacting customer support, provide them with detailed information about the issue, including the model and any relevant serial numbers. They may be able to provide specific solutions or arrange for repairs or replacement parts if necessary.
It's worth noting that the steps provided are general guidelines, and the specific troubleshooting process for your Gazelle Power Plus Glider may vary. Always refer to the user manual or contact the manufacturer's customer support for model-specific instructions and recommendations.
