Little Tikes Cozy Coupe Logo
Question about Little Tikes Cozy Coupe
I need to remove the cap nut from the axle of a Little Tikes Cozy Coupe. So far, I've only been able to remove the red, plastic material that covers the cap nut. Any help will be greatly appreciated! Thanks!
Posted by offerdahl7 on
  • Jeff Koski
    Jeff Koski Apr 01, 2018
    HI, For anyone still wondering I took mine off today to get ready to paint the cozy coupe. I used a strong vice grip type pliers such as Alloy Steel Locking Pliers but large channel locks might give you enough grip too. I then grabbed the rim with ones side of the pliers and the other end was more or less on the little nipple of the cap to sort of pry it and bend the rim up and away from the hubcap. I did tha on the axle cap on 4 opposing sides. Seemed to loosen them up enough that I could spin them off easily whild holding the opposite axle cap with a vice grip type wrench. Now to look for what size the caps are to order another off brand axle cap. Saw some black ones but want to make sure they are 3/8 inch which I'm assuming they are.
  • Jeff Koski
    Also 3 1/2" by 1/4" rubber binders work great wrapped around the outside wheels to buffer noise and vibration on the pavement. Wrapped a bunch around the tires. A dollar something from Walmart .. Zig zagged some glue and have held up more than a summer season. Was so amazing the first time out without all the noise pushing my son with a hoverboard.ha
Anonymous
Try gripping the axle with a pair of vise grips and use a pair of slip joint pliers to twist the cap nut off the axle.worked for me!
Posted on Apr 10, 2012
Jhon Jack
    New Friend:
Hi. I found best and fast way to take off caps. Taking around 1 min to do that, taking hammer and screwdriver, screwdriver putting in place with cut and hitting couple times in one side and other. After couple hits they popping out by self. Done four wheels in 5 min. Thanks
Posted on Jul 28, 2015
  • Greer Poulin
    Greer Poulin Dec 25, 2016
    Oh my god THANK YOU
mj turner
    New Friend:
I found the solution to removing the axle caps! Pry off the red plastic cap and use a Dremel tool with a heavy grinding wheel to cut off the metal cap. Took five minutes to remove two axle caps!!!
Posted on Apr 16, 2015
Ray Chavez
    New Friend:
Tools required
Hammer, flathead, Vise grips.
1. Lay car on side upside down with top of facing your lap.
2.Push wheel up until rod sticking out as far as possible.
3.Vise grips close to lowest setting grip the exposed rod just below acorn nut.
4. Have spouse, partner, or buddy hold Vise grips. Single parent, no worries, rest Vise grips against knee.
5. Take flat head screwdriver and slide in between opening of Vise grips from outward facing side, positioning it underneath acorn nut.
6. While holding rod secured, and screwdriver in place. Strike end of screwdriver with hammer.
7. Release Vise grips, turn rod. Repeat 1-6 until removed.
Posted on Oct 10, 2014
Anonymous
    New Friend:
I just re-did the front wheels on my grandson's Cozy Coupe. It's a very old Coupe, that had totally seized front wheels. I removed the plastic decorative 'hubcap' (black, on mine) with large pliers, twisting it off. Note that they would NOT go back on, so there may be a more elegant method. If my 1-year old complains about no decorative hubcap, tough luck! I then removed the metal wheel retainers that pinch onto the axle (and actually hold the wheel in place) by GENTLY shimmying them off with a large slot (flat blade) screwdriver, BIT-BY-BIT, rotating as I shimmied - raise it a little bit at the 6 o'clock position, then move the screwdriver to 9 o'clock and raise a smidgen more, then 12 o'clock, 3 o'clock, 6, 9, c. After about 10 or so tries, off it came. Be careful: one sprung off and flew about 10 feet onto the lawn, although my wife was sharp eyed enough to find it. This retaining clips went back on no problem. Once off, I had to wire brush and Dremel-stone down the built-up corrosion on the axle, until the wheel rotated freely. Then a dab of axle grease, replace the wheel, and re-install (the rusty old used) wheel retainers the same way I took them off: push a bit here, a nit there, rotating around until they were ALMOST flush with the wheel. Don't push them on too tight, or they will bind the (front) wheel, leave just the slightest little bit of play.
Posted on Nov 19, 2012
  • denise wells
    denise wells Dec 24, 2013
    Use a giant pare of channel locks! works like a charm!
2 Related Answers
Anonymous
  • 223 Answers
SOURCE: little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
Posted on Jun 15, 2009
Anonymous
  • 4234 Answers
SOURCE: Little Tikes Cozy Coupe red plastic wheel caps
The caps are a type of "acorn nut". Check a local hardware store (not the big guys) for this type of fastener and bring the shaft with you to get the correct size. These should not cost more than about $.50 each.
Dan
Posted on Apr 09, 2009
I put the front wheels on the wrong side can I remove the axle cap and and change the wheels and put the axle cap back on
Unlikely, because the caps tend to self district instead of coming off. Replacement acorn caps should be less than a dollar at a hardware store or a lawnmower repair shop.
The wheels on our Little Tikes Cozy Coupe do not turn/swivel easily
Not a solution but I wondered if you ever sorted this? I have same problem with one front wheel only... Just seems too snug a fit to the main body...? Any suggestions?
Bent tip of rear axle
http://www.buynicer.com/wholesale-RC-Helicopters_cid129.html
Our 2yr old grandson was given a red cozy coup. However, the axle rod connecting the 2 back wheels is partially out. The only way to get it back in is to remove a wheel & slide the rod back through....
This link:
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2485&
shows which replacement parts are available from Little Tikes, and I don't see the one you're looking for. I tried to call their Consumer Services line at 1-800-321-0183, but they're open M-F from 8 am to 8 pm and Sat 9 am to 2 pm, EST. Please give them a call tomorrow.
An alternative might be to take the piece to a hardware store and see if they have anything that might work as a replacement.
Hope this helps!
15helpful
2answers
I put the front wheels on backwards on the cozy coupe and can't get the red caps off...any suggestions?
Wedge something like a screwdriver under the cap and twist. They usually pop off with a little help.
Otherwise pliers from the top while rocking back and forth may work.
We just purchased the 30th Anniversary Cozy Coupe and I messed up with the right and left side front wheels, I put them in the wrong sides. I need to switch them but the red Metal Cap Nut in the front...
I have dealt with many of these metal push nuts, best thing is to break the plastic off with a needle nose or regular pliers and then that will expose the metal push nut, then you can bend that with the pliers and pull it off and swap the tires to the correct sides, keep in mind this will ruin the push nuts and new ones will need to be ordered off ebay or something similar
Little tikes cozy coupe
7helpful
4answers
Dan
Top Little Tikes Toys Experts
Marvin
Marvin
john h
W.L.
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
