The drive belt only brings power from the motor to the mechanism driven by the hand wheel. Some machines have more than one belt; the other belts are part of the stitch selection mechanism. However, I'm not sure about your model.
http://www.searsarchives.com/history/files/sewing_id.pdf lists a 158.492 and a 148.392 but no 153.392. A more likely issue for an older sewing machine is that the stop motion mode is engaged. This disengages the needle bar connection. Does your machine have a knob inside the hand wheel? If so, hold the hand wheel and turn the knob away from you (clockwise). For other machines, check if the bobbin winding mechanism needs to be moved to the left. If these aren't the case, then a linkage between the hand wheel and the needle bar isn't connected properly. The machine would need to be disassembled to find the problem. For any machine with a computer control, this is best done by a sewing machine repair technician unless you have experience with repairing electronics.
I hope this helps. Please add a comment if you misread the model number for further assistance on how the bobbin winding mechanism might be stopping the needle bar. I have assumed that you can freely turn the hand wheel.
