The first possibility is that the sewing mechanism has been disengaged (as if for winding a bobbin). Hold the hand wheel firmly and turn the disc in the center of the hand wheel back (away from you) until it snaps in. Check if the machine runs. If not, does the needle bar move when you turn the hand wheel; always turn the hand wheel towards you. If the needle bar does move with the hand wheel only, you may need a new motor belt for the machine. The replacement belt is available at several parts stores, including https://www.sewingpartsonline.com/pfaff-1471-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=1 . If the belt is fine, then the motor carbon brush or brushes could be faulty. These are also available at SewingPartsOnline.
I hope this helps.
SOURCE: pfaff 1471 foot problem. Foot wont go down all
Try lubricating the pressure foot shaft where it slides up and down (2 Places). To do this you need to remove the left side cover - the flat black screw in the slot under the left side of the carrying handle. Back the screw off slightly and pull off the left side plate. This should allow you to oil the shaft. I use Mobile 1 Synthetic 0W-20 oil. I find it works extremely well, as good or better than sewing machine oil. The problem is caused by the original grease they used when these machines were manufactured. The grease hardens over time (especially if the machine hasn't been used for awhile) and causes the shaft to stick. You might need to use a little penetrating oil initially, especially if the shaft is really stuck. This is a fine machine - good luck... LS.
SOURCE: Pfaff creative 1471 wont' work
sounds like the motherboard may be going out & the machine needs
to be checked
SOURCE: I have a Pfaff Creative 1471 and the pressure foot...
I have had my machine for many years and this is about the only problem I have had with it. I had taken it to 2 different repairs shops about 2 years ago and the repair worked only temporarily. The only reason I had not tried this solution before is that I didn't know how to get the side cover off to reach the mechanism. I just recently learned how and the oil worked like a charm after a little cleaning with a Q-tip. At least now if the problem reoccurs, the fix will be easy and free.
the computer motherboard could have went out
or the motor
