Question about Necchi 4595 Mechanical Sewing Machine
I have a Necchi Supernova Julia sewing machine, and unfortunately after 30 years of excellent service the needle clamp no longer works. The needle falls out now. My repair shop says it's impossible to find a used needle clamp, and it must be the exact match. While I'm at it, a girlfriend lost my box of accessories and cams when she borrowed it, and the manual as well. I still LOVE this machine, though. Does anyone have any suggestions? Is anyone parting out an old Supernova Julia? Thanks! Robin ([email protected])
Posted by robinharlow on
  • Betty Wilson Jun 07, 2019
    I have two Necchi sewing machines one is a super nova and one is a 445. They came with Manuel's and lots ofattachments. I only wanted the cabinets. Would you be interested in parts off machine or attachments..
Lorene
    New Friend:
I had what I thought was the same problem with my Necchi Supernova Julia 534. Turns out it was the needles. Buy a new package that you know are right and try them.
Posted on Dec 29, 2012
Pattianne Madeo
    New Friend:
Join the Necchi Yahoo group: Necchi Sewing Machine Club, Once a member you can also join the Necchi Sewing Circle group where you can download a manual for your machine & search for solutions to the needle bar problem. This problem was actually discussed in a recent group digest. AND, some members have part out machines.
Posted on Oct 15, 2012
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Try ebay for a parted out machine.
Posted on Mar 18, 2009
Necchi automatic supernova Julia; zig zag won't engage
There is a lever for positioning the needle bar. When you move the lever to the left middle or right , the needle bar too should follow the same. Try to do that. If it doesn't follow the lever and stays at one end, that means the machine needs to be oiled. Not like most sewing machines Supernova swings the bottom rod too to left and right when Zig Zag is engaged. I recommend to spray some WD 40 first, to inside of top and bottom side of the machine , and later to apply machine oil to every moving joints.
Feb 20, 2016 | Necchi Sewing Machines
Necchi needle bar screw
it would have been helpful if you had provided the model number of the Neechi sewing machine.
But if you go to this website you should be able to locate the correct part for needle bar clamp and screw.
Necchi Sewing Machine Parts
Aug 05, 2014 | Necchi Sewing Machines
Necchi supernova manual
Most sewing machines can use a double needle, the one with the single mounting shank and it turns into two needles.
MAKE sure you have Zig Zag needle plate installed to accomodate the double needle.
Turn hand wheel slowly to test then use thread and fabric and turn flywheel by hand to test sew.
Jul 19, 2014 | Necchi Sewing Machines
Necchi supernova julia power problem
sounds like a sew-tric plug an motor if so under the motor's electrical connection cover there is a wiring diagram moulded onto it
Feb 24, 2014 | Necchi Sewing Machines
A foot control that works with necchi Julia
call or email these sites and ask them
sewvacdoctor.com
a1sewingmachines.com
Jan 26, 2013 | Sewing Machines
We have a 48 year old necchi sewing machine and
Dad taught me to service machines when I was about 12. Back then, foot pedals ran on small discs of carbon, and he gave me lots, to service My foot pedal. That was circa 1960. Likely you need a replacement foot pedal. I would look for one on Ebay. Just - where I find all sorts of 'Stuff'.
Jun 09, 2017 | Necchi Sewing Machines
Can't get part and cam for Necchi Supernova Julia
Try the Necchi Yahoo Group. There are members who often sell parts and they also are very knowledgeable and helpful.. You should also try eBay. They have parts for lots of vintage machines. You may not find what you are looking for right away but look often as things show up everyday.
https://groups.yahoo.com/neo/groups/Necchi_Pfaff_Sewing_Machine_Collectors/conversations/messages?messageStartId=9&archiveSearch=true
Jul 11, 2017 | Necchi 4595 Mechanical Sewing Machine
Need belt for necchi supernova automatica sewing machine
You can also use a Eureka vacuum cleaner belt, can't remember the exact model, but the package says it's for most sewing machines. It's not the V belt, but it works on my Super Nova and it's 1.79 for two!
May 09, 2009 | Sewing Machines
Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
Apr 24, 2009 | Necchi 4595 Mechanical Sewing Machine
I have a Necchi supernova Julia 534
sounds to me like a tension issue, also are you using rayon or polyester thread, this is just a recommendation for those types of threads,,,,,,but please check your tension, is it only doing it during automatic
Jan 21, 2008 | Necchi 3101 Mechanical Sewing Machine
Necchi 4595 Mechanical Sewing Machine Logo
2,356 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
