Computers & Internet Logo
T
Trevor Taylor Posted on Sep 18, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My shhors resist SH759 watch
How do you change date time
ADMIN Eric
Level 3:
Top Expert:
  • Time Master 39,394 Answers
  • Posted on Sep 18, 2021
ADMIN Eric
Time Master
Level 3:
Top Expert:
Answers
39394
Questions
0
Helped
806301
Points
588774
Make of computer may help you get an answer.
Testimonial: "asus"
Steve Madden LED touchscreen watch
To change the date and time on your Steve Madden LED touchscreen watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you may be able to find information on how to set the time and date online or by contacting Steve Madden customer support.
To set the time and date on most LED touchscreen watches, you will need to press and hold a button on the side of the watch for a few seconds until the time and date display appears. You can then use the buttons on the side of the watch to set the time and date. The specific buttons you will need to use and the sequence for setting the time and date may vary depending on the make and model of your watch.
As for the timer, you will also need to refer to the user manual for instructions on how to use it. The timer function may be accessed through the watch's main menu or by pressing a dedicated button on the side of the watch. Again, the specific steps for using the timer will depend on the make and model of your watch.
If you are unable to find the user manual or are unable to set the time and date or use the timer function, it is recommended to contact Steve Madden customer support for assistance. They will be able to provide you with specific instructions for your watch.
Dec 25, 2022 • The Watches
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
Need manual / instructions for shhors watch
Mine is like those but brand shhors. I change time by holding reset. What concerned me is what are the digits displayed: first comes time, then comes the month and the day in small digits, and then comes 20 and two digits for year which is soon 23. After youre done reset finishes all.
Dec 13, 2013 • Watches
1helpful
Can't change minute , day and date on shhors Lego watch
Whilst on the normal time screen; press MODE 3 times passing through STOPWATCH, and ALARM. Now back on the time screen; you should be able to press RESET to move through all the fields on the screen and ST/STP to change number/value. Pressing MODE once more goes back to normal time screen use. Hope this helps. Nich.
Aug 10, 2013 • Watches
4helpful
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
How to set the date in sector sge 650 2653960035 watch? Thanks.
Unscrew crown. Some models of Sector Sport watches may have a screw down crown. Watches meant to be used in water will often have this feature. To test this try spinning the crown freely in both directions. If it does not spin freely it has a screw down crown. If your Sector has a screw-down crown, turn it in a counter clockwise motion to unscrew it until it pops free.
Pull crown out one click and set date. If the watch has a date perform this step, if not move on to the next step. Pull the crown out one click. Twist crown clockwise and counter clockwise to set the day and date to the previous days day and date. The purpose of this is to set the date by setting the time and insuring the watch is in the correct a.m. and p.m. mode.
Pull crown out to the next click and set time. Pull the crown out the to next click. This is the time setting mode. Set the time by turning the crown clockwise until the day or date changes to the current date. This is the a.m. mode. Continue to the correct time. If it is a p.m. time this will require moving one full circuit of the dial past the twelve again and then to the correct time. If you fail to do this, the date will change at noon. If there is no date, simply set it to the correct time.
Push in and screw down crown to retain water resistance. Push crown down into its furthest setting. If it is a screw-down crown, press the crown in with a finger and twist it clockwise. Be careful here not to cross thread the crown in the crown tube or it will need to be replaced. It should be smooth and easy to turn. If any pressure or resistance is felt stop and start over. If you fail to screw in a screw down crown your Sector Sport watch will not be water resistant.
Jan 16, 2013 • Watches
I dont know how to change the time? I have no
to press left side upper button and right side butom button to set the time
My Geneve watch, model "Seapearl" is only two months old. It keeps good time but the date is behind by 1 day. How do I adjust the date? I have tried to pull the stem but it will not move.
The stem (or crown) is sometimes screwed in to improve the water resistance of the watch. Try turning the crown anticlockwise before pulling it out.
It may be necessary to take the hour hand past midnight to get the date to change. This will be the case if there is only one "out" position.
If there are two "out" positions then one will be for the date and one for the time.
Jan 16, 2010 • Watches
6helpful
How can i make the date of my tag heuer formula 1 change automaticaly?
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Top Time Computers & Internet Experts
Thomas Perkins
Thomas Perkins
NOEL
NOEL
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
