Question about Time Computers & Internet
SOURCE: Microsoft Wireless Notebook Optical Mouse Not Connecting
After reading on Microsoft about replacing the batteries, down loading drivers and "press the button on the receiver and the connect button the receiver" - I got frustrated and almost gave it flight. Then my wife stepped in and realized that there was a green reset button on the USB connector as well. (who knew?) SO.... you press the green light (which is a button) and release it.... should blink. Then go to THE MOUSE portion and press the connect button for 5 seconds or so.... and wala...... One mouse that plays again! This ones gonna cost me! :) I hope this one works for ya!
Posted on Oct 01, 2009
SOURCE: Logitech wireless keyboard and mouse (ex 100) won't connect
use the secured keyboard connection you have to push a combination of keys then a 16 digit code but then your keyboard should work
Posted on Mar 03, 2010
SOURCE: Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Posted on Aug 20, 2010
SOURCE: My wireless mouse won't work.
Try replacing the batteries. You can also try this link--->http://support.microsoft.com/kb/838398
Posted on Nov 17, 2010
SOURCE: need new USB 2.4 GHz transceiver for my wireless keyboard
I found a 2.4ghz tranceiver that I have no use for. Am broke but would take bottom dollar for it...
Posted on Apr 29, 2011
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red X right update driver
W7
hope this helps
