Computers & Internet Logo
Question about Time Computers & Internet
During setup an incorrect year and time entered. how do I reset them
Posted by Sheri Jennings on
Andrew T23
    New Friend:
  • 6 Answers
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
Posted on Sep 29, 2018
  • octavia
    octavia Jul 12, 2022
    not taking about computers here am asking about BFIT WATCH
1helpful
2answers
Change pin number
hard reset by recovey options
I cant download anything as it says my apple I.D is incorrect
Log unto Itunes. DOuble check your APple ID Credentials. Create new apple ID if you must. Restore your iphone and complete setup procedure. You would be asked to enter your apple ID Credentials once more during setup.
1helpful
Seting time
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date.
Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date
press F10 to save to cmos and restart
hope this helps
Bad check sum cmos
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
hope this helps you
My board is MSI P6NGM-L ,for about a year using my desktop,sudenly set on stand by mode,how can i fix it?or reset it?
During the boot process you will see on the screen to press a certain key to enter setup
or you might try
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
1helpful
After 5 years of playing region 2 DVD's machine comes up with "incorrect region code" and ejects
  1. Open the disc tray
  2. (Press SETUP and scroll to 'Lock')
  3. Press 0 seven times
  4. (Press ENTER, Setup)
How to reset the raido
There is a trick to the procedure. You have to turn the key to position 1 or the first stop on the ignition. Turn on the radio and wait between 2.0 to 3.0 hours for the radio to reset and ask for the code. From the owners manual. My 97 takes between 2:25 and 2.5 hours to reset. Every radio is different.
To enter the code:
After installation or when the set has been disconnected from power, the set displays "codE" when it is switched on.
Enter the 4-digit code using the preset buttons. If the correct code is entered, "on" is displayed and the set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
During this waiting period:
the battery must be connected
the ignition key must be turned to position I
the unit must be turned on
Make sure the headlights are turned off to help prevent battery drain (please refer to page 2:6 for information on turning the headlights off). Enter the code again once this time has elapsed.
Ryan
2answers
Bios checksum error. How to solve it?
If you are using an old computer, there’s a possibility that you already encountered this error message during bootup; “CMOS checksum error – Defaults loaded”. At this point, the PC will halt its operation and requires you to press F1 to continue or DEL to enter setup (mostly but also depends on motherboard) to proceed.
This is caused by incorrect or corrupted CMOS values. BIOS settings are stored in CMOS. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, the error message will be displayed.
For most cases, this is caused by the motherboard battery. Buy a new one to any electronic retailers in your area and replace it. Turn on your computer and press the stated key to enter the BIOS setup. It can be DEL for some or F2 but this depends on your computer. On the BIOS menu, try to change the DATE and TIME settings because their values are reset to different value. Most settings are set to default so leave it as it is. Save the settings and reboot your computer.
3helpful
2answers
IN 120 base keeps flashing CL
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Top Time Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Thomas Perkins
Thomas Perkins
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
