Question about Time Computers & Internet
Appreciate the direct "Ask Me".
To your concern; hinge repair is relatively easy, what is more challenging is opening the lid and figuring out how to improve the hinge action to reduce the stiffness of closing the lid. For a pictorial illustration on how to open the lid cover to expose the hinge, please reference this page. For a generic how-to on hinge repair, pls check this out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 17, 2008
SOURCE: Message ID . . .
This is a JetDirect error and can be cured by adjusting the IO and Idle timeout values. Set the IO Timeout (or Job Timeout) to 300 seconds ( 5 minutes) and set the Idle Timeout to somewhere between 900 seconds (15 minutes) and 3600 seconds (1 hour). Setting the IO Timeout (or Job Timeout) and Idle Timeout to 0 does not disable them. It causes the printer and/or print server to timeout immediately. The IO Timeout can typically be set through the control panel on the printer, or it can be set using the HP JetAdmin Utility. The Idle Timeout can be set by TELNETing to the TCP/IP address for the printer, or it can be set using the HP JetAdmin Utility. The HP JetAdmin Utility can be downloaded from HP's Web site, www.hp.com.
The print job is defaulting to tray 1 so you will need to change this at the application and printer driver admin and not at the printer itself.
Posted on Oct 26, 2009
SOURCE: I have a 13-15 year old sharp tv that will worksome times
well if you really love this set,then i suggest you change all or most of the fast switching diodes,usually 1n4148 Nte519 mainly around the micro,video and abl circuitry.Also alot of capacitors especially the ones around heat sources,eg heat sinks and wirewound and flame proof resistorsI.If you want the service manual for the set,i have over 1000 sharp schematics,i am sure i have that one.Please request it at [email protected]
Posted on Nov 23, 2009
SOURCE: reading old messages sent on facebook
scroll down your home page keep clicking on older posts if it was in the last few days you should find it so you can read it.
Posted on Jun 07, 2010
SOURCE: Starmate reciever (about 6 years old) shows
unhook the power to it for about ten to 15 minutes. hook the power back up and let it "boot" up. that should fix the issue
Posted on Aug 24, 2010
