Dishwashers Logo
L
Lucille Rhoton Posted on Sep 13, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I purchase replacement racks for my P/No 385ODD3006E LG Dishwasher
ADMIN Eric
Level 3:
Top Expert:
  • LG Master 39,391 Answers
  • Posted on Sep 13, 2021
ADMIN Eric
LG Master
Level 3:
Top Expert:
Answers
39391
Questions
0
Helped
805335
Points
588769
If still in production LG may have them but as they are not normally needed for a warranty repair, I wouldn't hold your breath, as they are not likely to fail under warranty.
How to uninstall upper spray arm for LG dishwasher D1453
To be ale to remove the upper spray arm on the dishwasher pull the upper rack forwards and then turn the nut located above the spray arm and under the rack in a counterclockwise turn and then pull down. The spray arm will become loose to be able to detach and remove . To take out the top spray arm start first by removing the cutlery rack.
Lg dishwasher top rack sprayer gets no water and not not spraying, middle rack sprayer gets water but not spinning. Bottom rack works fine
Check and make sure the tubes that go into the back of the dishwasher are aligned. Sometimes they get out of place.
LG modelLD-1403W dishwasher. The bottom spray arm
The wheels on the bottom rack could be broken or collapsing..or the rack is distorted or bent..or the spray arm is not attached correctly or is damaged.
Plastic clips failing
Hi Tom,
Can you confirm that you are talking about the LG 5811 dishwasher? Thanks!
10helpful
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Top rack is not level. Glasses and cups roll forward
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
LG DIshwasher
hi Problems with the dish racks usually occur because the racks have been jammed back into the tub housing after they're fully loaded. Careless handling can exert enough force to crack or break the roller wheels or throw the racks off the tracks. The solution is easy: Stop jamming the racks.
The repair is easy, too. Remove the racks by pulling out the tiny metal pins that hold them in the tracks. Or simply lift up on the racks and pull them out of the tracks. Then reinstall the racks on the tracks so that they roll smoothly. If the rollers are cracked or broken, replace them with new ones of the same type. The rollers may be friction-fit to their hubs. Pull them off for replacement. Or, if they are held by tiny spring clips, pull the clips out with pliers, or pry them out with the tip of a screwdriver. If you can't pull the rollers off for replacement, remove and replace the entire rack.
Kenmore Dishwasher model 16779
Age/ poor quality plastic/sharp objects making contact/these are all common examples,I know there is a liquid plastic that you can purchase that really works and is safe to use.You wipe on the damaged areas and let it dry .
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
