SOURCE: sony trinitron 6 red lights
Every part has its unique reference number on schematics and PCB of TV installed.
C515 means Capacitor # 515 and IC206 means Integrated Circuit # 206 mounted on PCB and shown in related schematics.
Jungle IC is technical term used in Sony and Panasonic refers to sync, oscillators, drive stages for horizontal and vertical deflection stages in a TV.
Need further info, let me know.
SOURCE: Convergence IC STK392-110 vs STK392-110T
Based on your post above it sounds like the chips you tried were knock offs and not original Sanyo chips. They will look almost identical but the knock off chips will only last a month or two.
Here are some of the most common symptoms of a convergence problem.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
SOURCE: sony trinitron power will not come on sometimes
Hi
Can you give to me your diagnose test result..
Thanks!
SOURCE: Sony KP53S25 rear projection TV - Horizontal lines on display
try this link
see this link and try to understand the blink codes.
this will surely help you
SOURCE: TV will not turn on
Sounds like the thermal fuse has gone bad. Sony part# 191002393. Very enexpensive part. It is located near the lamp housing from the back of the set. Once you have the new part in your hand, it will be easy to find.
