SOURCE: Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
SOURCE: kenwood dishwasher flashing E3 towards end of
As far as I know, E3 on a Kenwood is related to the temperature sensor, when you open it, are the dishes warm?
Testimonial: "thanks for that did not think of the temp and yes dishes sometimes come out cold "
SOURCE: I cannot open the door after the finish of the
Hi There
I have found this for you to read.let me how it goes. Hope this was helpful.
F/dL
Door
Lock Error
A
Door Lock Error occurs if the door cannot be unlocked. It
will try to lock it 6 times before displaying the error.
Thank you for writing to fix ya.
Best Regards Richard
