This is the flood code. Shut the power off at the main and remove all the water from the inside manually and then reset and try it.
I fixed e4 error on my Kenwood kdw45b16/a I kept on getting the e4 error every time took the dish washer apart please don't attempt this if you are not confident or know what your doing and found that one of the hoses was leaking it is an easy task to do and ordered the part from espares just under £18 with next day del
I had a similar problem with Whirpool (these https://www.bestadvisers.co.uk/integrated-dishwashers model) and Rick siegel tip helped me
SOURCE: I have a kenwood KDW12SL3A.
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
SOURCE: I HAVE A KENWOOD KDW12ST3A
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
SOURCE: powerpoint dishwasher E4 error code
The solution below applies to a Powerpoint dishwasher but is probably a generic one for E4 problems - given that brandnames are frequently badges of convenience for made-in-china products.
The problems cause and solution goes as follows:
Problem:
Any water that leaks (for whatever reason) from the internals of the machine finds it's way down to the lowest point of the machine - down under the washzone and into the area where all the workings of the machine are located. There's a sensor there (a polystyrene float operated switch in fact) that detects this water - causing the machine to empty and go into error 4 (E4).
The solution will depend on the nature of the leak. If it's due to one of the various seals on the floor of the washer leaking or there is some problem with water level controls then that will have to be repaired first - otherwise you'll keep on getting the error. In my case however, the "leak" was actually a design feature of the machine and is easily rectified.
Open the dishwasher door fully and look at the floor of the machine where it meets the bottom of the door. You'll see a couple of plastic tubes protruding from the floor by about 12mm - one to the left and one to the right. Their function appears to be to act as an overflow if the water level in the machine gets too high (for whatever reason). This excess water is directed down these tubes and into the bottom of the machine where it can be detected - rather than letting it spill out onto your expensive floor. The weakness in this system is that it only takes a soup spoon of water to produce the error - something which might accidently happen during the course of a normal wash.
Options:
1) Leave the machine idle for a few days until the water evaporates. The sensor switch will reset and the error will be gone when you switch on.
For either of the following solutions, turn off the power to the machine by unplugging it or tripping the relevant switch at your fuse board
The stainless steel washcabinet is only slightly thicker than aluminium kitchen foil. Handle the machine gently and never force it otherwise you're in danger of distorting the cabinet.
2) Tilt the machine right the way forward so that the water leaves the area of the sensor. It'll flow back again once you level the machine but in wetting the floor area of the machine, the level at the sensor will be a little lower than before - permitting the sensor to reset. Switch on and the problem should be gone.
3) Pull the machine out from the built in unit to gain access to the right hand panel. Remove it (just a lot of philips screws holding it on) and you can just about see the polystyrene float (near the front) and the slightly depressed area underneath it - in which the water accumulates. You can poke a stick in with some tissue taped to it to mop up the water. Be careful not to disturb or damage the float.
note:
I've had this problem occur twice in as many years. If it keeps on occurring then you likely have a genuine problem with water level controls during filling or a leaking internal seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
SOURCE: Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
