Question about LG Televison & Video
Sounds like T'Con board fault. Please contact the authorized service center for LG.
Posted on Mar 03, 2021
Testimonial: "I ordered a new tcon board. Did not fix it. Still doing the same thing"
SOURCE: Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Posted on Jan 02, 2007
SOURCE: Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Posted on Oct 03, 2007
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
SOURCE: Hi, I have a 37lc46 LG LCD which takes ages to
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 07, 2010
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Jan 25, 2013 | Emerson Lc320em1f TV
Aug 24, 2012 | LG Televison & Video
Aug 06, 2012 | Televison & Video
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Dec 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
