SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
SOURCE: GE Vivid i portable echo machine not powering up
It was a problem in ac adapter. I tried to plug in the ac adapter into the machine turning 90 degrees each time and at one specific position it turned on and battery also started charging.
SOURCE: blinking green light on the back of hp pavilion
1. Your smps is OK for power supply
2. check the beep sound for RAM and Video card (If it is long beep the RAM is having and short and frequent the Video card) o
3. Remove RAM then start ssytem see the response shoutdown, clean the RAM place it back start the ssytem
4. Remove the CMOS battery or short the jumber for any setting in BIOS start the ssytem
5. Disconnect all the cables connecting motherboard including Hard disk except SMPS power supply to Mother board
SOURCE: I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
SOURCE: Standy mode system wil not turn on
When you connected the speakers, one of the following may have occurred: 1) Crossed the wires (smoked the outputs) 2) Presented too low an impedence load to the amp section (overheated and smoked) There are other possibilities as well, but those are the most common. In any case, try disconnecting hte speakers altogether and trying to turn on the system. If it turns on, then the problem is either the wiring or a bad speaker. If the system stil won't power up completely, then the output section needs to be checked. These units have discrete output transistors that can be checked by a service shop. These are not too expensive but are somewhat unique to Aiwa systems. Figure on $20-$40 for parts. Dan
