Hi Heather, I was in search of the same manual, for the Memorex 9290MMO. I thought I had lost it, but I just found it. I am selling the player but I will scan in the manual first. I will check this post for your update. Shawn
Hi, First make sure yoou are using correct cds. You need CDR Audio discs not blank pc media type (Yes they are different). Once you have the disc type right, make sure you are finalizing the disc as they will not play in other machines until u do this
There is a small loading belt that is slipping. The noise you hear is the loading motor. When in the loaded position, there is a "clamper" that magnetically attached to the hub assembly to clamp the disk in place. It takes quite a bit of force to open this up. If you feel comfortable working inside the unit, you can try to gently lift up on the clamper assembly while you are trying to open the tray. That may provide enough to release the tray to open. Replace the loading belt with a new one and your problem should be resolved.
