20 Most Recent Memorex MVT2135 13 in. TV/VCR Combo Questions & Answers
4answers
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
11/13/2013 9:05:08 AM • Memorex MVT2135... • Answered on Nov 13, 2013
How to turn off subtitles without the remote control?
Yes, you can. Find your way into the setup menu to "cc" /closed caption and turn them off.
7/10/2013 2:06:42 PM • Memorex MVT2135... • Answered on Jul 10, 2013
2answers
Close caption
Should be under the menu/setup button on remote under close caption.
7/10/2013 7:26:11 AM • Memorex MVT2135... • Answered on Jul 10, 2013
How do I get the picture?
The TV is usually set to Channel 3 or Channel 4. You may have a switch on the back of the VHS recorder near which is marked Ch3 Ch4.
Once you correct this, try the following procedure.
Some VHS have a tracking button that allows the user to tune to the best signal. The tracking can also be done from the remote controller.
Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
6/23/2010 9:56:50 PM • Memorex MVT2135... • Answered on Jun 23, 2010
We were just watching a vhs movie on our tv/vcr
Some VHS have a tracking button that allows the user to tune to the best signal. Usually that tracking function is used as follows.
6/23/2010 2:05:48 AM • Memorex MVT2135... • Answered on Jun 23, 2010
I can`t get any audio. Its not on mute. I can turn
First check that any muting control is not activated. This might be a button on the remote or set itself. If you have a headphone jack, it may have dirty contacts as plugging in a headphone usually mutes the speaker.
If the set is mono or only one channel of a stereo set is out, then check for bad connections to the loudspeaker. Test the loudspeaker by disconnecting one of the wires (with the power off!) and measuring its resistance with an ohmmeter (it should be less than 100 ohms - probably less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or audio signal tracer) and schematic. Or at least the part number off of the chip. Is the final amp a chip also or just a transistor? Have you tested the transistor? If there is little or no buzz from the speaker, that would indicate a problem fairly near the output. If the tuner/if were bad, I would expect some noise/hum pickup from the low level audio stages. Get the part number off of the chip. If it is in a socket, check the contacts for corrosion or looseness.
Hope it works...
6/1/2010 1:48:15 PM • Memorex MVT2135... • Answered on Jun 01, 2010
I just hooked up a cable to my Memorex, and do not
Using the remote, click on menu and find setup. Click on it and answer the prompts. Regards, Joe
1/7/2010 2:56:38 PM • Memorex MVT2135... • Answered on Jan 07, 2010
VCR has no color picture is clear but black and white
this is a vcr head dirty, use a good tape cleaner, and test for level of screan dots on record video,and dont use low quality tapes (give heads short time of life).
11/22/2009 9:52:02 PM • Memorex MVT2135... • Answered on Nov 22, 2009
Vee, V, a Vee Cee Rrrrr ? Not a DVD?
If you are playing a VHS tape that should be color content and it's in Black and White ... well you could check the tracking control if there is one on that model. Otherwise it sounds pretty broken. Probably NWR. Not worth repair. Try Cleaning the heads with a cleaning tape???
11/22/2009 9:48:51 PM • Memorex MVT2135... • Answered on Nov 22, 2009
I need a universal code for a memorex mvt 2135
Try these: 0503, 0520, 0617.
6/22/2009 5:46:07 PM • Memorex MVT2135... • Answered on Jun 22, 2009
2answers
Some of my channels on my tv dont work with the converter box
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
6/2/2009 2:01:15 AM • Memorex MVT2135... • Answered on Jun 02, 2009
Can't get time and day display off screen
With the MT1192 Memorex set, it's the RECALL button on the remote that toggles it on and off the screen.
2/14/2009 5:16:56 AM • Memorex MVT2135... • Answered on Feb 14, 2009
2answers
Manual for MVT 2135
I imagine one can figure it out by going through some menu button on the remote and if not well, it won't be long before that function will be no good because next year in Feb, you'll need a converter box to receive TV shows which will be HDTV quality, though you can hook it up to your current TV and just use the record button to record the source from that box. Hope that helps.
1/4/2009 5:17:27 AM • Memorex MVT2135... • Answered on Jan 04, 2009
2answers
Sub-title does not appear.
It's called "closed captioning" and should be under the menu/setup button. Subtitles are only for DVD players.
11/6/2008 1:51:12 AM • Memorex MVT2135... • Answered on Nov 06, 2008
VCR
Maybe it's full, try it again when the vcr is hungry/empty or if it is empty take it back to where you adopted it because it's sick.
10/17/2008 10:17:46 AM • Memorex MVT2135... • Answered on Oct 17, 2008
Memorex MVT2135 13 in. TV/VCR Combo Logo
37 questions posted
Top Memorex Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Memorex Televison & Video
Most Popular Question
programming device control code memorex
  • Televison & Video
