20 Most Recent Memorex MVDT2402 24 in. TV/VCR/DVD Combo Questions & Answers
If its on 9 will it not change channels or what is the issue?
Memorex MVDT2402... | Answered on Jun 15, 2012
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Memorex MVDT2402... | Answered on Jan 17, 2011
The easiest thing to do is switch off the power at the wall socket, or disconnect the plug completely. Then leave everything off for 5 minutes. After that reconnect and there is a very good chance the set will respond.
Memorex MVDT2402... | Answered on Jan 08, 2011
Hello
Three digit universal remote code for Memorex are:-
002 115 206 502 506 601 701 706 000/ 001/ 004/ 009/ 046/ 049/ 051/ 135
Four digit universal remote code for Memorex are:-
0004 0009 0049 0051 0135 0031 0000 0268 0310 0001
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON the Tv each time with its front panel power ON/OFF switch, before trying an other code.
OK.
Memorex MVDT2402... | Answered on Jan 03, 2011
check your remote on the menu screen go to sound and click on stereo
Memorex MVDT2402... | Answered on Dec 18, 2010
Either press the TV/AV button on the remote until the tv gets selected or just press on the 5 button from the remote and the tv will switch automatically to this channel.
Memorex MVDT2402... | Answered on Nov 05, 2010
The snow is the sign that no signal is received. LINE1 is the audio channel used by default - none are detected so you are notified of that.
You get this because either the antenna is badly adjusted, the cable from it has a break in it or the tv isn't tuned into a channel - you should do that from the menu.
Memorex MVDT2402... | Answered on Sep 26, 2010
I would suggest you to unplug the unit for a while (around 30 minutes), then just plug it back in. If that does not work, you will have to take the TV to a local repair shop.
Memorex MVDT2402... | Answered on Aug 16, 2010
Better try to find the origonal remote rather than find a code from the latest universal remote. Universal remote has fewer buttons so that many discrete functions can not be used without extra buttons especially with combos that had three devices in one TV.
Memorex MVDT2402... | Answered on Aug 15, 2010
RETIME THE GEARS
Memorex MVDT2402... | Answered on Jul 17, 2010
check that the power supply motor in the vcr burned out.
Memorex MVDT2402... | Answered on Jul 14, 2010
I work for Memorex tech support. Our number is 800-919-3647.
Unfortunately, Memorex TVs and DVD players can not be controlled by universal or cable remotes. If you need a replacement remote, please call Memorex's parts distributor, Fox International at 800-321-6993 to make the purchase. If they no longer have stock, try www.remotes.com.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Memorex MVDT2402... | Answered on Apr 21, 2010
Try website 1-800-Remotes Factory original.To buy an exact remote.
Memorex MVDT2402... | Answered on Apr 02, 2010
Either the disk is worn out or the files on it are in the wrong format.
Memorex MVDT2402... | Answered on Jan 09, 2010
Hey I have the same situation Go to MR REMOTE.com and give them your tv model usually will have a new manufacture remote under $30.00 ( just add Batteries and it works)no codes to enter!) I think the Memorex is lacking on the universal codes Especially for the DVD/TV/VCR combos
Memorex MVDT2402... | Answered on Nov 24, 2009
Memorex MVDT2402 24 in. TV/VCR/DVD Combo Logo
Popular Tags
39 questions posted
Top Memorex Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Memorex Televison & Video
Most Popular Question
code universal remote
  • Televison & Video
