Garden Logo
Posted on Sep 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Anonymous
Level 2:
  • Expert 174 Answers
  • Posted on Sep 20, 2009
Anonymous
Expert
Level 2:
Answers
174
Questions
0
Helped
112352
Points
430
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
No pressure
sounds like valves inside are stuck more so if any water was left inside the unit
I have a excel 2600 psi and there is no spark, the engine is a Honda
could be many things...get a new spark plug...check plug lead not rubbed and shorting out on body...take flywheel off and check/replace cdi...or points if it has them.
No pressure on Honda 2400psi pressure washer
spill valve aka unloader valve is stuck needs to be cleaned and lubricated with grease re instaled
2answers
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
3helpful
2answers
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
1helpful
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
2answers
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
