20 Most Recent Karcher Electric Powered Hot Water Pressure Washer HDS 2.3/12 C Ed Questions & Answers
Hi
How i shall connect the 4 cable to the switch 700-2/6 its for cable.
Blacc-Brown- blow- rosa.
Best regads George
Karcher Garden | Answered on May 20, 2020
search and check for damaged gear or motor damage
Karcher Garden | Answered on Apr 03, 2020
A clogged carburetor is most commonly caused by leaving fuel in the pressure washer for a long period of time. ... This sticky fuel can clog up the carburetor and cause the engine to run stall. If the carburetor is clogged, try cleaning it with carburetor cleaner.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Pressure-Washer/149---/Pressure-Washer-Starts-Then-Stalls
the one thats leaking.. most likely an o ring you can get at your local hardware store
Karcher Garden | Answered on Apr 01, 2020
A modern hot water pressure washer can have complex circuitry and it is a good idea to read the user instructions and have a diagram for reference when troubleshooting - certainly some dismantling will be necessary to trace the power rather further inside than the power cord.
If the unit hasn't been used for a time the pump could have frozen and have overloaded the motor when switched on - there is often a facility for the pump to be turned by hand to unfreeze the pump before switching on.
Karcher Garden | Answered on Feb 09, 2020
Which breaker does it trip? The MCB or the RCD?
If the former, the motor is taking too much current and that might be caused by shorted turns, a defective centrifugal switch (if fitted) or a shorted start or start/run capacitor.
If the unit has been standing for a while it could be the pump is frozen - some units provide access for a hexagon key so the pump can be turned manually a couple of revolutions before switching on the power.
If the RCD has tripped it is because there is an insulation breakdown and current is leaking to ground.
Karcher Garden | Answered on Oct 17, 2019
In my experience with karcher, and other brands, you will be money ahead to replace the pump entirely. Pumps usually cost around $125. There are some times rebuild kits available, but they will often cost over half the amount of an entire pump. Add to that the unloader valve, & you will be way past the cost of a new pump.
Karcher Garden | Answered on Oct 15, 2019
The float in carb is not shutting off suply when the carb chamber full so the fuel is constanly filling the carb this is known as flooding carb either the float needle is mis aligned with the needles seat or theres a object or deris the seat stopping it fully closing off the fuel flow cheak thease the float may also damaged and filling up with fuel this stops it riseing and again the carb floods
Karcher Garden | Answered on Oct 01, 2019
If it's new take it back with your receipt and let them fix it.
Karcher Garden | Answered on Sep 23, 2019
I have repaired several of those almost every one of them would not build pressure due to the the 3 plungers each one has a small screen a small spring and a small rubber disk need to take them out and clean and inspect there is a repair kit they sale for that power washer that gives you every thing I describe but they are more than likely clogged up be careful taking it apart the parts are very small well lighted room clean floor just in case you drop something
Karcher Garden | Answered on Sep 16, 2019
limited information generic answer find whats leaking and fix or replace it
Karcher Garden | Answered on Aug 27, 2019
Karcher Electric Powered Hot Water Pressure Washer HDS 2.3/12 C Ed Logo
0 questions posted
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
karcher 2700 pressure washer after first
  • Garden
