Question about Karcher 2500 PSI Pressure Washer
I have a Karcher 3000 psi with Honda GC190 6.0 engine. At 25 months, home use 2 summers, engine cam came apart & timing belt cut in half. Mechanic say he has seen this frequently with Honda engines. Is this true?
Posted by mhuestis on
Anonymous
  • 38 Answers
Honda engines are know to be very well and durable.
Posted on Jul 11, 2009
Anonymous
    New Friend:
I have a Karcher K2300G pressure washer with a Honda 5hp engine, with a 3/4 shaft. Can i change out a complete 3000 psi pump in place of the 2300 psi ?
Posted on Mar 30, 2011
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Changing the oil. What's the best way to do this?
get an empty half gallon plastic coke bottle, cut the bottle in half and use the bottom part to collect the oil, remove the oil dipstick, place the cut bottle under the hole and tip the engine on the side.
Aug 13, 2014 | Simpson PowerShot PS3000 3000 PSI Honda...
What type of fuel to be filled in 5.5 honda (R) Over cam
If engine has a place for oil, then use ordinary gasoline.
If engine does not have a place for oil, then you use 2-cycle mix with the gasoline
If you have a power washer, there are normally 2 places to put oil.
1) in the pump head >> use SAE20 or SAE30 >> fill it about half way.
2) At bottom of engine is a screw-out plug >> use 10-W30 oil >> fill until it comes up 1/2 or 2/3 up on dip stick.
Oct 30, 2010 | Karcher 2500 PSI Pressure Washer
2003 V6 Accord engine failed
If the cam jumped a few teeth the pistons would likely hit the valves. You could have holes in 4and 5 pistons or broken rings
Jul 26, 2010 | 2003 Honda Accord
White smoke. when it won't start, raw gas comes out of the exhaust GS190 honda Karcher 3000 PSI
Sounds like it's flooded. Close the throttle and open the choke if equipped. Pull it through a few times and then open the throttle a bit.
May 24, 2010 | Northstar Pressure Washer 3000 PSI
I have a Karcher 3000 model G3060 OH WITH hONDA G190
It may be due to some water getting into the engine. I would change the gas and change the oil.
Sep 10, 2009 | Karcher G3025OH Pressure Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
2,010 people viewed this question
Top Karcher Garden Experts
Bruce Robin
Tim Venetis
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
