20 Most Recent Karcher Hose Reel Questions & Answers
it is possible the rewinding spring broke .
Karcher Hose... | Answered on Feb 13, 2018
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Karcher Hose... | Answered on Feb 07, 2010
return it to Walmart
Karcher Hose... | Answered on Jun 23, 2009
Hi
How i shall connect the 4 cable to the switch 700-2/6 its for cable.
Blacc-Brown- blow- rosa.
Best regads George
Karcher Garden | Answered on May 20, 2020
search and check for damaged gear or motor damage
Karcher Garden | Answered on Apr 03, 2020
A clogged carburetor is most commonly caused by leaving fuel in the pressure washer for a long period of time. ... This sticky fuel can clog up the carburetor and cause the engine to run stall. If the carburetor is clogged, try cleaning it with carburetor cleaner.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Pressure-Washer/149---/Pressure-Washer-Starts-Then-Stalls
the one thats leaking.. most likely an o ring you can get at your local hardware store
Karcher Garden | Answered on Apr 01, 2020
A modern hot water pressure washer can have complex circuitry and it is a good idea to read the user instructions and have a diagram for reference when troubleshooting - certainly some dismantling will be necessary to trace the power rather further inside than the power cord.
If the unit hasn't been used for a time the pump could have frozen and have overloaded the motor when switched on - there is often a facility for the pump to be turned by hand to unfreeze the pump before switching on.
Karcher Garden | Answered on Feb 09, 2020
Which breaker does it trip? The MCB or the RCD?
If the former, the motor is taking too much current and that might be caused by shorted turns, a defective centrifugal switch (if fitted) or a shorted start or start/run capacitor.
If the unit has been standing for a while it could be the pump is frozen - some units provide access for a hexagon key so the pump can be turned manually a couple of revolutions before switching on the power.
If the RCD has tripped it is because there is an insulation breakdown and current is leaking to ground.
Karcher Garden | Answered on Oct 17, 2019
In my experience with karcher, and other brands, you will be money ahead to replace the pump entirely. Pumps usually cost around $125. There are some times rebuild kits available, but they will often cost over half the amount of an entire pump. Add to that the unloader valve, & you will be way past the cost of a new pump.
Karcher Garden | Answered on Oct 15, 2019
Karcher Hose Reel Logo
Popular Tags
11 questions posted
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
karcher detergent draw problem
  • Garden
