SOURCE: RCA 32'' TV
Unfortunately, the Power Supply has spat the dummy out. It is giving enough power to light the LED but not enough to run the set. To replace it will probably cost more than buying a new set. But ask around your local repairers for a price before you make any decisions...
SOURCE: What is the code for RCA model RLDED3258A-B
082,091,057,029 are the codes to check. If you wish to get more setup codes, check this link. Pull up older posts there. Setup code list and proceedings to some popular brand remote controls are given.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
This model does not have a mirror setting on the service menu
It doesn't have general settings in the service menu either to get to mirror
