20 Most Recent RCA VR701HF VHS VCR Questions & Answers
manual
I can not get into the menu to come up?
On page 6 of the manual it specifies the following things to check out if the menu does now come up on the screen. ----------------------------------------------------------------------------------------- If the menu does not appear: (page 6 of user manual) • Make sure the TV is tuned to the same channel as the CH. 3/4 switch or the TV's video input channel (see "How to Find Your TV's Video Input Channel" in the References section of this manual for more information). • Make sure the VCR indicator is on in the VCR's front display if the VCR is connected using the ANT. IN and RF OUT jacks. • Check your connections to make sure they are correct and snug. ----------------------------------------------------------------------------------------- If you chose to set up the VCR's options individually, then go to the next section for specific menu instructions. ------------------------------------------------------------------------------------------ I hope this helps. Cheers - walt
3/7/2016 8:39:17 PM • RCA VR701HF VHS... • Answered on Mar 07, 2016
I do not have power but I verified int incoming to
the power supply starts at the plug and, extends along the edge of the vcr to the front; it has a heavy line and, the word: "hot" printed on the circuit board; separating it from the "cold" DC side of the VCR circuit board.
1/16/2010 9:18:00 PM • RCA VR701HF VHS... • Answered on Jan 16, 2010
2answers
RCA 52 inch television worked and turned on, but when I relocated it upstairs it will not turn on. What's the problem please?
Hi Ward. What's the model of your TV? Some models of Funai sets had issues with the connector that goes to the button/IR board, since it worked before it was moved, I'd try that. Unhook the connectors and hook them back up, depending on the model and location sometimes these are hard to reach. If that doesn't fix it try unhooking the connector going from the power supply to the main board.
8/10/2022 7:02:10 PM • RCA Televison &... • Answered 7 hours ago
RCA 52" Television. After relocating it to upstairs, it wont turn on, but did before moving it?
Are you sure the wall socket is ok , have you tried another outlet .
8/10/2022 10:07:32 AM • RCA Televison &... • Answered 16 hours ago
2answers
Rca 52inch tv wont turn on after relocating it whats the problem
Been damaged/wires moved etc etc.
8/9/2022 9:38:35 PM • RCA Televison &... • Answered Yesterday
2answers
Rca 60 led full hdtv model rled 6090 cuts on then goes black
Might be of back-light fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview by mobile. Mobile View has no search box.
8/6/2022 5:12:38 PM • RCA Televison &... • Answered on Aug 06, 2022
My RCA model rdr323 keeps shutting down after 10 to 20 minutes after starting?
say the word drying it is not RCV radio. at all , posted to TV video the dryer vents are clogged or vent screen or inside the dryer is full of lint and ever cleaned. (dismantlement) RCA 3.75-cu ft Ventless Electric Dryer (White) I have no idea how ventless works seems like fantacy but there will always be lint so we know that , so how do they manage lint, (a filter is the only way ) so clean it. it shuts down from sensors inside seeing it oveheat. if not filter packed it needs tech service,
8/3/2022 1:28:27 PM • RCA Televison &... • Answered on Aug 03, 2022
After changing the main board on my rca rtu5540-d, picture now is split on the screen, does any one know how to fix it?
You installed the wrong board, it's common to see 3 or more non interchangeable main boards on RCA TV's the main board matches the panel, different mains for different panel. It won't be a firmware update.
7/26/2022 11:13:56 PM • RCA Televison &... • Answered on Jul 26, 2022
2answers
Brand new TV, it was good. Turn it on and only black screen appears?
what input did the store use, what input are you using. you may need to go to setup and select the input you will be using.
7/26/2022 2:21:22 PM • RCA Televison &... • Answered on Jul 26, 2022
I changed my RCA TV main board & now picture is split in 2 and not crisp
Hi Tony, I bought a board from TVPARTS in Canada and now I have the very same problem. I have a 55" RLED5536. What is your model? The man at TVPARTS said the board has to be reset by a technician and I can't do it at home I asked him why didn't he reset it before sending and I received no answer. There is no reset button. I have tried the reset by holding power button after unplugging the TV and that did not work. I cannot reset it using the menu. So did you buy it from the same store? Did you replace the TCON board too or just the main board? Most of these main boards come from Canada because RCA is owned by Curtis.
7/26/2022 12:46:18 PM • RCA Televison &... • Answered on Jul 26, 2022
2answers
Rca led52b55r120q wont turn on. the red light comes on when plugged in but when power button is pressed red light turn off and tv does not turn on.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/10/2022 4:37:54 AM • RCA Televison &... • Answered on Jul 10, 2022
Hannspree wont turn on, intermittent power light?
HI, I'm not familiar with this brand set but in most cases, you can't replace a main board from another size set and have it work. I'd get the right board and see if that fixes it. I'd say the power supply voltages are ok, anything within 10% of rated should be ok, but the voltage to the tcon doesn't sound right, again a main board issue.
7/7/2022 10:11:07 PM • RCA Televison &... • Answered on Jul 07, 2022
Rca RTU9500 flashing from one solid screen color to another. I cant even access the menu or setup as the remote wont work when this happened
Your TV has gone into service mode now and the colours that are showing up on the TV screen is a test pattern.To stop that yo need to unplug the TV from the power outlet and the wall and hold down the power button for 20 seconds.
6/12/2022 8:41:47 AM • RCA Televison &... • Answered on Jun 12, 2022
29 inch rca tv power light on but screen flashes then black
It's your LED lamps that have failed but on a smaller set like this it may not be worth repairing as a new set is real low cost
6/3/2022 12:22:04 PM • RCA Televison &... • Answered on Jun 03, 2022
2answers
RCA LED55C55R120Q PUSH POWER BUTTON MULTIPLE TIMES TO TURN ON
That has to be one of the longest questions I've seen on here but unfortunately it doesn't help figure out what's going on, you've replaced the power supply a couple times, but you didn't say anything about testing the 5 and 12 volt rails to see if you have the correct voltage and if it's free of ripple. Have you tested the "on pin" on the power board to see if the power supply is being commanded to come out of sleep mode and turn on? Another thing to test is the on command to the main board, I'd have to pull a service manual to see what it should be but generally it's around 2.5 volts on most Funai brand sets. To be able to repair a TV it generally takes some electrical engineering knowledge and takes more than just replace some boards and hope it helps.
5/24/2022 1:26:02 PM • RCA Televison &... • Answered on May 24, 2022
RCA TV Model LED65G55R120Q Only half backlight LED's flash at start up, then all go out Voltage to LEDS seem to be correct, LED Circuit shuts down. Hard to believe half of LEDS are bad. Any advice?
Hi Keith, your set has two backlight circuits, one side sounds like it's working however the other string has at least one diode that's either open or several that are shorted, and the overload section of the backlight inverter are shutting down the negative side of the supply causing no backlights. This is why you see one side come on for a moment then shut off, new strips will fix the TV
5/15/2022 12:30:49 AM • RCA Televison &... • Answered on May 15, 2022
2answers
Watching tv and screen just went black. I can still hear sound but no picture at all.
backlight may have gone if your tv has one
5/14/2022 1:14:01 AM • RCA Televison &... • Answered on May 14, 2022
RCA VR701HF VHS VCR Logo
4 questions posted
Top RCA Televison & Video Experts
AAA TV Service
AAA TV Service
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
not get into menu come up
  • Televison & Video
