Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below.
Instructions
If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .”
If the printer uses a power module
Follow the steps below to ensure power is properly supplied to the printer:
Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
Disconnect the power cord or adapter from the wall outlet.
Disconnect the printer data cable from the printer.
Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
NOTE:
"The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
If the power module/cord works on the other printer, then this printer is defective. Service your printer.
If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord
Disconnect the power cord from the wall outlet.
If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
If the power cord does not work on the other printer, it is defective. Replace the power cord.
If the power cord works on the other printer, then this printer is defective. Service your printer.
If another printer is not available to test with, carefully inspect the power cord for damage.
Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
Disconnect the power cord from the rear of the printer.
Unplug the power cord from the wall outlet, power strip, or surge protector.
If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
Wait 15 seconds.
If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
Reconnect the power cord to the rear of the printer.
Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
Wait 15 seconds.
Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
just because the batteries are new, does not make them good. Did it work with batteries before, try the batteries in something else like a flashlite.. Also does the radio have a ac/dc switch.
that means the power cord is faulty, the monitor does no send message to the power cord rather the power cord sends message to the monitor so its the power cord that's bad expecially if its an adaptor, thanks
The product uses a power cord, if the power supply is a power cord with electrical connections at each end.
Figure 1: Power cord
The product uses a power module, if the power supply is a power cord connected to a power module.
Figure 2: Power module
If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product.
Figure 3: Power module
Check
User’s Guide to make sure that the proper power module is being used.
If the power module has a permanently attached power cord, do the following.
Disconnect the power cord from the product.
Wait 30 seconds.
Reconnect the power cord to the product and the wall outlet.
If
the power module has a detachable power cord, disconnect the power cord
If
the product does not turn on, or the power light built into the power
cord does not glow, plug the product into a wall outlet in another room.
If
the product or power light turns on when connected to a wall outlet in
another room, there is an issue with the power supply in the previous
room.
If
there is still no power to the product, then the power module, power
cord, or product might be defective. Proceed to the next instruction.
Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
If
the power module or power cord works on the other product, the product
facing the issue might be defective. Proceed to Step four: Service the
product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product.
Figure 4: Power cord
If the power cord is damaged, replace the power cord.
If the power cord is not damaged, continue with the next instruction.
Wait 30 seconds.
Reconnect the power cord to the product.
Reconnect the power cord to the wall outlet.
If the product still does not turn on, plug the product into a wall outlet in another room.
If the product turns on when connected to a wall outlet in another
room, there is an issue with the power supply in the previous room.
If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
If the power cord works on the other product, the product facing the
issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product
If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
part number for power cord u want to order just select ur choice and order it online or call hp in U.S 800-BUY-MYHP or for others find contact here www.hp.com
Power Cord (Europe)
8120-6262
Power Cord (Denmark)
8120-8881
Power Cord (Israel)
8120-8883
Power Cord (South Africa)
8120-8886
Power Cord (Switzerland)
8120-8885
Power Cord (United Kingdom)
8120-8882
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
