My HP Photosmart D5160 won't power on?
The product uses a power cord, if the power supply is a power cord with electrical connections at each end.
Figure 1: Power cord
The product uses a power module, if the power supply is a power cord connected to a power module.
Figure 2: Power module
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product.
Figure 4: Power cord
Won't power on - c00057913.jpg="/uploads/images/c00057913.jpg" alt="c00057913.jpg" class="h_mi" />
Step four: Service the Product
If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Posted on Jun 17, 2009
SOURCE: problem of my printer photosmart d5160
Connect the printer dorectly to the wall outlet.try unplugging waiting for 30 seconds and replugging the printer.
Now check if you still face this issue then its a hardware malfunction with your printer no need to worry.
Call up hp at 1800-474-6836 and lets see what else can be done.
SOURCE: HP Photosmart D5160
Hi Arnie,
Infact the machine cover is not a customer replacable part, hence u ll not be able to open it . however if u try to open it make sure u ll not break the bezel.
thanx .. nd best of luck
Posted on Jun 15, 2008
SOURCE: Flashing red light won't correct on HP Photosmart D5160 printer
Here is a HP document that explains what the blinking lights mean and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01041365&dlc=en&product=1155996
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 30, 2008
SOURCE: how do i clean my hp photosmart d5160 printer?
Hello sir; The primary cleaning way is print head and ink cell, Open the cover let ink cartridge move to the center then UNPLUG power cord, now you freely to move ccarrier for and back.
Posted on Aug 05, 2009
SOURCE: HP Photosmart D5160 gives error message
Issue
The product displays an 0x ... error code when printing (for example
Error: 0xf0af8004). These error codes indicate that the product has an
internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover.
If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Posted on Mar 05, 2011
Sep 13, 2011 | HP Photosmart D5160 InkJet Printer
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
May 17, 2011 | HP Photosmart D5160 InkJet Printer
Sep 21, 2010 | HP Photosmart D5160 InkJet Printer
Aug 23, 2010 | HP Photosmart D5160 InkJet Printer
Jul 01, 2010 | HP Photosmart D5160 InkJet Printer
Nov 16, 2009 | HP Photosmart D5160 InkJet Printer
Mar 05, 2009 | HP Photosmart D5160 InkJet Printer
Nov 07, 2008 | HP Photosmart D5160 InkJet Printer
Aug 05, 2008 | HP Photosmart D5160 InkJet Printer
May 27, 2008 | HP Photosmart D5160 InkJet Printer
Jun 09, 2014 | HP Photosmart D5160 InkJet Printer
4,622 people viewed this question
