Maytag electric dryer model # SDE4606AYW started with not heating and then all of a sudden won't even start now. the timer still moves and the light inside comes on. do you know what could be the problem?
SOURCE: my maytag electric dryer all of a sudden stopped
sounds like youve lost one leg of power to the unit, the element uses 240 volts and the motor and timer are connected one on each 120 volt leg to balance out the electrical load chk your input power for 240volts first
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
