Additional youtube video, but for a 7-4612A:
https://www.youtube.com/watch?v=5ef_II9GY_k
Hi Larry, I sent you the link to download the user manual of a GE 7-4812, which is similar to your GE 7-4613, follow the steps indicated there for the selection of the alarm and you can enjoy your GE
Regards Franco Dosil
Hola Larry, te envio el link para que descargues el manual de usuario de un GE 7-4812, que es similar a tu GE 7-4613, sigue los pasos indicados ahi para la seleccion de la alarma y podras disfrutar de tu GE
Saludos Franco Dosil
https://www.manualslib.com/manual/138579/Ge-7-4812.html
https://i.ebayimg.com/images/g/vsAAAOSwDX9b50fQ/s-l300.jpg
SOURCE: Setting a Radio Station for Wake Up
You can download the manual from the link below: http://157.254.235.130/public/RP3721%20EN.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Fisher Slim- 1800
with the unit turned off press memory once and the hour digits flash.
Press the cd ship |<< or >>| buttons to adjust the hour.
Press memory again and the minute digits flash
Press the cd ship |<< or >>| buttons to adjust the minutes
press memory once more. the display stops flashing and the clock has been set.
SOURCE: clock radio
Unless thate is an internal fuse it that blew, most likely it will be more expensive to repair than replace. The transformer primary winding is probably burned out. You have nothing to lose, take it apart and see if there is a fuse. If so, replace it with the EXACT same value as the original. If not, its not worth fixing.
You didn't say what the symptoms were, other than it didn't work anymore. I am assuming it is completely dead.
Please let me know if I can be of further assistance to you.
- Jim
SOURCE: Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
SOURCE: do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Tips:
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
You can select your CD wake track by the following procedures:
