How do I set the alarm on my Nelsonic NLC690 alarm clock radio to 94.9 the bull?
I have a Nelsonic Clock Radio, model nlc 608 a. How do I use the radio? Thank you!
To use the radio function on your Nelsonic Clock Radio model NLC 608A, please follow these steps:
  1. Make sure the clock radio is plugged into an electrical outlet and turned on.
  2. Press the "Radio" button to turn on the radio function. The display should show the current radio frequency.
  3. Use the "Tune +" and "Tune -" buttons to tune to the desired radio station. You can also hold down these buttons to automatically scan through the available stations.
  4. Adjust the volume using the "Volume +" and "Volume -" buttons.
  5. To switch between AM and FM radio, press the "Band" button.
  6. If you want to save a radio station as a preset, tune to the desired station and then press and hold one of the numbered preset buttons (1-10) until you hear a beep. You can then access the saved station by pressing the corresponding preset button.
  7. To turn off the radio, press the "Radio" button again or simply turn off the clock radio.
I hope this helps!
1helpful
Set time on alarm clock nlc695 nelsonic
Hi Joe.
this is all i could find.
How to set Nelsonic alarm clock? Press and hold the ALARM BUTTON to enter ALARM SETTING MODE. While still holding the ALARM BUTTON down, press and hold the HOUR and MINUTE BUTTONS until you see the time you want on your LCD DISPLAY. Release the TIME BUTTON and the Alarm Clock Radio will return to NORMAL TIME MODE.
USER GUIDE Alarm Clock Radio - Jazwares
jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf Search for: How to set Nelsonic alarm clock?
or go to this link might help you.
how to Set time on alarm clock nlc695 nelsonic Google Search
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
