Question about The Audio Players & Recorders
I could not locate a manual searching on the internet using http://www.google.com
If you go on Amazon, the vendor has answers to over 80 questions, and promises to answer questions, so that may be helpful to you.
https://www.amazon.com/ask/questions/asin/B073R7ZHVC/7/ref=ask_ql_psf_ql_hza?isAnswered=true
Example:
Question:
how do you create more playlists?
Answer:
Sorry,you can't create more playlists,you can only move the music which you like to one of the playlists,there are three playlist on this item,thank you
By Tihoosky SELLER on December 21, 2017
Posted on Apr 29, 2018
SOURCE: Creating Playlists
You need to do the following steps: 1. While the song is playing, press and hold the joystick button. A screen will pop up. 2. Select 'Favorite (+)'. Once you do this, you should be able to see the song in your 'Favorites' folder.
Posted on Jul 19, 2007
SOURCE: Gogear 6330/17 - Creating/Adding Playlist
You MUST use Windows Media Player 10 - Windows Media Player 9 or 11 will not transfer the playlist correctly. Once you have version 10 installed, then the instructions in the HDD6330 user manual will be accurate.
Posted on Sep 14, 2008
SOURCE: how do I create playlists?
The manual, etc is available at www.p4c.philips.com
You will have to, unfortunately, set up your Windows Media Player for Auto-Sync (has definite drawbacks - inclduing: adding songs, pictures, etc that you DON'T want into the GoGear). Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
Posted on Dec 12, 2008
SOURCE: samsung yp-u3 mp3 cant create playlist
ignore every thing you've heard so far, ive tryed everything i could hear, read, or find. the only way i have found to make a playlist on a yp-u3 is to download a Winamp player. this player is free to download at many sites.ive finally got a playlist on mine and it was simple.... good luck!!!
Posted on Dec 20, 2008
i have a problem with mine adding songs to playlist 3. it works fine aslong as there are only one song in it. but when i add a second song or more, it replaces the previous songs with the new song. i tried to format the player, but after that it still would not work. how in the world can i fix this?
what do you use to put videos in this mp3 player? it needs the amv video format. how to do that? have any idea?
for the user manual :http://www.ruizutek.com/manuals-firmware...
