Question about Sony ICF-C318 AM/FM Clock Radio ( White )
My ICF-C318 automatically switches the radio on around 5.0am when it is not set, ? why
I make sure it is switched off before I go to sleep, but the radio has started to come on around 5.0am- wakes me up too early to get up!!
Posted by Mrs Barbara... on
2 Related Answers
Anonymous
SOURCE: cant set the time on my Sony ICF-C318 digital clock
thank you all for giving me your solutions, but i managed to fix the clock myself when my dog accidentally stepped on it (which isn't exactly a great solution so don't try it if you have the same problem as me). Actually it turns out my clock was missing one of the buttons for adjusting the time when I looked at the box it came in, but somehow stepping on it seemed to fix it. Thank you very much though for all your help....if I ever have troubles with anything else I'll know where to post my problem!
thanks again
peanuts
Posted on Apr 09, 2009
Anonymous
  • 8197 Answers
SOURCE: I can't set the time
You can get the manual on the link below. Just click on Operating Instructions
http://esupport.sony.com/perl/model-documents.pl?mdl=ICFC318
Posted on Mar 14, 2011
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
1helpful
How do I get the alarm to work? I set the alarm for 5am, it did not go off. The sound is off, I have the volume to the highest point, nothing comes out.
Make sure it's on the correct am/pm. Also, make sure that it's not set to radio, or auxiliary, or anything. If it's still not working, I would try to return it.
I Need an instruction manual for a clockradio...model no1CF-C318.Thank you
That's a Sony model ICF-C318, I believe. You can get the manual here.
I ned a manual to help set my sony icf-c318
http://esupport.sony.com/US/perl/model-documents.pl?mdl=ICFC318
2answers
The time has changed here in Ohio, and we need to roll back an hour, have lost manual. How do I change time?
http://www.retrevo.com/support/Sony-ICF-C318-Clock-Radios-manual/id/2727ci362/t/2/
you can download the manual from here, chk n change ur time from it
njoy..
Cant set the time on my Sony ICF-C318 digital clock
thanks again
peanuts
Sony ICF-C318 AM/FM Clock Radio ( White ) Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
