HOW TO DISSOLVE SIDIMENT IN DRAIN PUMP HOSE
Hi Douglas Haskell, I know you will laugh at this but try Coke a Cola. Fill the Drain Pump Hose with Coke and let it Soak overnight.
Or CLR might help also
https://www.woolworths.com.au/shop/productdetails/74394/?istCompanyId=909b5da6-e33c-4de8-a6e2-0861c4cbcd86&istFeedId=c54e05d9-bacb-45a1-aa5a-c48531ceab7d&istItemId=wrimlwmml&istBid=t&cmpid=smsm:ds:GOOGLE:Woolies_SmartShopping_Home%26Outdoor:PRODUCT_GROUP&gclid=EAIaIQobChMIwv6B28fl5AIVgoBwCh3mrAZAEAYYASABEgL6iPD_BwE&gclsrc=aw.ds
I have not got round to it but I am planning to use Coke on my toilet to clean the calcium sediment under the water line.
SOURCE: Affinity Front Load Washer E21 first, now E23
E21 Water not pumping out fast enough. Refer to test (3). E23 Drain pump relay on control board failed or wire off pump. Replace control board or wire. 1. Check the drain hose for restrictions. Restriction. Correct problem. No restriction. Go to step (2). 2. Start the washer and check for 120 VAC at the drain pump. Zero. Replace the control board. 120 VAC. Remove the pump and check for blockage. If blocked, remove the restriction, if not, replace the pump.
SOURCE: whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
SOURCE: I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
SOURCE: how do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
drain pump.
