Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
How do i rest an electrolux front loader ewf 1080, i have replaced the drain pump and water chamber and now it says e20. drain itself is totally clear and no kinks in the hose. do i have to reset the machine after i have replaced the parts?
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Posted on Jul 19, 2012
SOURCE: How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
Posted on May 04, 2011
SOURCE: my electrolux ewf 1481 front loader wont spin
Turn the power off. At the wall and that will release the door to open
Posted on Feb 08, 2012
SOURCE: electrolux Front Loader 7 Kg Error
From the manual
E20W Problem with water draining
Solution from manual
Posted on Feb 08, 2010
SOURCE: how to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
Posted on Sep 26, 2010
Typically this is not a do it yourself repair and it is something that you want a certified professional to install for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem. Consider contacting your manufacturer for more details on who in your area can properly install this part.
